Old 06-16-2020, 06:31 PM   #1
Reasy
2014 Infotainment/GPS Incredibly Slow
Hey,
So, I have a 2014 Subaru BRZ Limited I recently bought and noticed how slow the media/etc. is on the infotainment. It was whatever to me and I just assumed that it was more than likely how the technology was stock. I just recently started using the GPS and noticed how unbelievably choppy it is and was wondering if this was normal (I assume it is), and if so, is there any way to possibly speed it up and make it less choppy(settings, etc.). I am 90% sure this is just how slow the infotainment system is and can deal but thought I would ask to see if there was anyone else that has messed with it and its settings for optimization. I've heard rumors of Subaru updating the machines but found those to more than likely false altogether as there is no data on the device. Just curious all around as to the rumors of the device and how well it actually can perform, specifically whether my very choppy GPS is abnormal.
Thanks
Reasy is offline   Reply With Quote
Old 06-16-2020, 07:13 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I recommend replacing the radio with a more modern aftermarket unit.
Crutchfield is an excellent retailer that’ll let you pick out a radio and they will build the harness for $25, so it’s truly plug and play. Install is very easy, takes 20mins.
My favorite is the Sony XAV-AX5000.
JDM radio filler panels can be found online, they look much better than the generic ones:
https://www.japanparts.com/parts/detail/43320
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Reasy (06-17-2020)
Old 06-17-2020, 01:25 AM   #3
Reasy
I love the look of it. How fast is it compared to OEM when it comes to connecting on vehicle start and just over a usage? Also does it have a decent GPS option that runs smooth? Seriously considering getting it as it is one of the cleaner models I’ve seen.
Old 06-17-2020, 01:43 AM   #4
Yoshoobaroo
TRACKBREAD
The clean look and UI is one of the main reasons I like it, most aftermarket units look waaaay too flashy and chintzy. It does not have built-in GPS though, you need to use CarPlay or AA for navigation, which works brilliantly. It also doesn’t have a disc drive, but Bluetooth streaming supports APTX and AAC, so it’s crystal clear even over BT. It starts up within seconds and is always very responsive.
brz, infotainment, subaru brz
PROJECT MAKE BRZ NOT SLOW SLOW BUILD andrewsbutt Member's Car Journals 33 10-11-2018 12:19 AM
AFR Incredibly high? SpeedFromSwede Software Tuning 22 01-20-2015 08:38 AM
Twins are slow? Not as slow as these cars! babydriver Scion FR-S / Toyota 86 GT86 General Forum 66 12-12-2014 12:09 AM
Why is my GoPro battery life so incredibly bad? qoncept Off-Topic Lounge [WARNING: NO POLITICS] 5 05-20-2013 01:43 PM
Infotainment madfast Electronics | Audio | NAV | Infotainment 67 09-18-2011 03:42 PM
