Old 06-16-2020, 01:31 PM   #1
Chaldea86
Drives: 2017 Toyota 86
Advice for tires.
I just got my 86 a month ago and I need to get new tires.
I was wondering if anyone could give me some advice on what tires to get? I want to spend around 500-600. I’m not doing anything crazy with it yet, so I don’t need any really high performance tires or anything. I’m on stock rims so I don’t think I can go any wider then 215. All help is appreciated.
Chaldea86 is offline   Reply With Quote
Old 06-16-2020, 01:34 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Advice for tires.
Stick with the stock size
In order of performance, can’t go wrong with these 4:
Falken FK510
Firestone Firehawk Indy 500
Hankook Ventus V12 Evo2
Michelin PS4 (out of budget but the performance benchmark for a street tire)
Even the Falken will be a nice step up in grip from the stock tires.
Old 06-16-2020, 01:34 PM   #3
Bardia
Drives: 2014 FRS
I upgraded the stock ones to Hankook Ventus V2 A/S tires; pretty grippy, good cornering but kinda weird in braking. They are much grippier than stock and actually prevent me from drifting in the dry. I'd recommend them as long as you don't have an issue with upgrading spring rates as they do bring out how soft the springs are.
Bardia is offline   Reply With Quote
Old 06-16-2020, 01:39 PM   #4
Chaldea86
Falken FK510
Thanks man. The Falkens look like just what I need.
Old 06-17-2020, 01:54 PM   #5
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Continental ExtremeContact Sport are just a hair over your $600 budget. But you get almost Michelin PS4S levels of performance.
N_Raged is offline   Reply With Quote
Old 06-17-2020, 05:33 PM   #6
HaXx
Drives: jrsc_brz
Dont sleep on bfgoodrich sport comp 2 uhp summers. Indy500 probably best bang for buck. I agree, keep stock size tire for your stock wheels
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 06-21-2020, 12:08 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
You guys are so lucky as you have an abundance of tyre choices in OEM fitmet.
I have decided to get new tyres this July, shortlisted Michelins, playing with Pilot Sport 4 or the Cup 2. No Pilot Sport 4 S option in the UK in OEM size.
Old 06-21-2020, 01:21 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
That's because your island spells tire wrong
Old 06-21-2020, 02:20 PM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
I think you may have a point.. but then again we do have more interesting 'A' and 'B' classification roads that really test out the tyres...
Old 06-24-2020, 10:13 PM   #10
bigfatcat
bigfatcat's Avatar
Drives: gt86
Falken FK510
I had Michelin Pilot super Sport on since 7 years ago. I think it's discontinued now but may be equivalent to the PS4 now. I really like the tire It's really grippy even in wet.
Now after 7 years the back has maybe 2mm of tread left, and front has minimal wear. is it recommend switching back and front on a square setup to get more life out of it? or should I just get new set? Would it understeer if I swap front and back?
bigfatcat is offline   Reply With Quote
Old 06-25-2020, 02:37 AM   #11
humfrz
Since your tires are 7 years old, I'd suggest you just get a new set. Then rotate them every now and then -
Old 06-25-2020, 10:58 AM   #12
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
The guy left with a set of Falkens a few posts ago. I also went with Falken 510s. I have yet to push on them, but they feel mushier than the Conti ECDW I came from.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 06-25-2020, 11:04 AM   #13
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
The only draw back with the FK510s is that they're a bit softer compared to others. My understanding is that they're designed around luxury performance, giving up a bit of turn in response.
Not an ideal sports car tire but still a good tire none the less.
Old 06-25-2020, 11:12 AM   #14
Yoshoobaroo
TRACKBREAD
I'm thinking of trying them next. which tires did you have before?
19" Wheels/Tires Advice JR007 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 05-24-2018 10:52 AM
Advice needed on 225/45R17 tires on stock rims babydriver Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-02-2015 09:10 PM
need advice for tarmac rally tires Walla Walla Tracking / Autocross / HPDE / Drifting 13 05-14-2015 01:46 PM
need advice for winter tires!!! ShowTime_DW Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-25-2013 12:57 PM
Need some advice on tires Touge86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 05-14-2013 10:21 PM
