Old 06-07-2020, 01:20 PM   #1
Doc2020
Drives: Orange GT86
Help with removal of plastic wrap from inside Vland headlight casing!
Hi everyone,
I wonder if I can get your help and advice on this.
I bought a set of vland headlights for my GT86. Unfortunately one of them arrived with a piece of plastic wrap inside the casing. I've been offered a discount so I'm keen on keeping them.
What would be the easiest way to get the plastic wrap out of the light casing.
Please see the photo attached.
Many thanks.
Doc2020 is offline   Reply With Quote
Old 06-07-2020, 02:57 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Honestly I’d make them replace it. You’d have to bake and pry the light apart best case, worst case cut it open and glue it back together. It’s a ton of work.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
asdf (06-07-2020), DarkPira7e (06-07-2020), Irace86.2.0 (06-07-2020)
Old 06-07-2020, 02:58 PM   #3
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Inside? You’d have to heat up the seals to pull the housing apart. You’d have to do it at your own risk but there is a diy on the site with associated steps: https://www.ft86club.com/forums/showthread.php?t=8788
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 06-07-2020, 03:01 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
and many times, heating and prying on aftermarket housings results in spidering of the uv coating on the polycarbonate lens. which then requires stripping and re-doing...
Old 06-07-2020, 03:10 PM   #5
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Like all mentioned above... Not worth cracking it open if you don't plan on modifying it, I would have exchanged it for another one...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 06-07-2020, 04:11 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Please send these back!
Old 06-07-2020, 07:00 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I would send them back. The only way is if the discount or refund was like half the price, AND I could solve the plastic problem without opening them up. How would I try? Maybe heat from a hair dryer could heat the plastic enough to shrink it down to a size and density that it can be worked to the back of the headlight housing. The other option would be to try and blow/suck the plastic out of the headlight from the back opening using compressed air or a vacuum.
Vland Headlight HID Bulb question (Need HELP) TMXSTAR Cosmetic Modification (Interior/Exterior/Lighting) 2 03-07-2020 07:15 AM
vland headlight bulb mcnvgget Cosmetic Modification (Interior/Exterior/Lighting) 0 11-14-2019 06:11 PM
VLAND Headlight HID Kit Kai Uhl Cosmetic Modification (Interior/Exterior/Lighting) 1 10-02-2019 11:49 PM
Vland Headlight question Sikku Cosmetic Modification (Interior/Exterior/Lighting) 2 04-12-2019 09:50 AM
Vland Headlight question Sikku Cosmetic Modification (Interior/Exterior/Lighting) 5 04-03-2019 02:46 PM
