Old 06-03-2020, 05:51 PM   #1
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
HKS Supercharger E85 Dyno Results
I just got back from some dyno pulls and here are the results,
310whp
222lbs torque
13psi boost
The full setup is - HKS GT V3 Supercharger with upgraded pulley kit, DW 900cc injectors, DW fuel pump, Borla UE length headers, Grams 72mm throttle body.
Ecutek tuned to run on E85.
I'm pretty happy with this. Power to weight ratio is now up there with the 370z Nismo, Mustang GT etc. I just hope it holds up and I don't end up in the engine rebuild thread!
BRZ_88 is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZ_88 For This Useful Post:
HaXx (06-03-2020), tomm.brz (06-04-2020), weederr33 (06-03-2020)
Old 06-03-2020, 06:26 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
310whp
222lbs torque
13psi boost
Lol only smash it when u need to. E85 is better than pump gas less chance of knock despite the power increase.
BlOody_BoOger is offline   Reply With Quote
The Following 2 Users Say Thank You to BlOody_BoOger For This Useful Post:
BRZ_88 (06-03-2020), jeepmor (12-23-2024)
Old 06-04-2020, 02:24 PM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
Are you running the grams with the red manifold?
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 06-05-2020, 06:09 AM   #4
BRZ_88
Imperator
It's this one https://www.ft86speedfactory.com/gra...l#.XtoY8kVKguU
No red manifold though.
I had some major idling and unpredictable rev issues after getting the supercharger installed, installing this fixed the problem.
The Following User Says Thank You to BRZ_88 For This Useful Post:
Joveen (06-05-2020)
Old 06-05-2020, 06:56 AM   #5
tomm.brz
Drives: brz 2017 hksv2
idling problems have nothing to do with stock throttle body
if you had idling problems, it was only fault of the tune and calibration of injectors and throttle body itself
Anyway great dyno pull!
Old 06-05-2020, 10:39 AM   #6
jflogerzi
jflogerzi's Avatar
Agreed. What kind of Dyno was this. Do you have a baseline for a stock car on this Dyno?
2013 Series 10 FRS #553
Old 06-05-2020, 06:28 PM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Is the throttle body a bottleneck at this power? Would be cool to see a dyno before and after the TB.
Old 06-05-2020, 06:32 PM   #8
BlOody_BoOger
Don't think it would be a bottle neck but for sure the grams has much more aggressive throttle response
The Following User Says Thank You to BlOody_BoOger For This Useful Post:
Irace86.2.0 (06-05-2020)
Old 06-05-2020, 06:42 PM   #9
Grady
Grady's Avatar
From what i have found our heads/intake valves are our bottleneck. That is why any induction changes/filters have little effect on power.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Irace86.2.0 (06-05-2020), tomm.brz (06-06-2020)
Old 06-05-2020, 09:12 PM   #10
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If only this kit was more reliable I'd love it take the plunge
MS, CSCS, TSAC-F, CPT
Old 06-06-2020, 03:34 AM   #11
BRZ_88
Imperator
My post may have been a bit misleading there, it was more of an internal sensor issue than a physical one.
I got a DTC code for the throttle position sensor after some test pulls, and unfortunately the only way to replace that was a whole new throttle body. It fixed the idling issue with no tune adjustments.
Old 06-06-2020, 03:43 AM   #12
BRZ_88
Imperator
It was done on a Dyno Jet 248.
A quick search shows a stock 2013 model produced 173whp on the same model of dyno (https://www.edmunds.com/car-reviews/...no-tested.html), so I'm getting an increase of almost 140whp with the new setup!
Old 06-06-2020, 04:17 AM   #13
GrabTheWheel
Drives: 16' BRZ
310whp
222lbs torque
13psi boost
It's funny my F56 Mini made the same exact numbers but flipped with just a reflash on pump gas. Curb weight is about the same too.
310 ft/lbs TQ
222 WHP
GrabTheWheel is offline   Reply With Quote
The Following User Says Thank You to GrabTheWheel For This Useful Post:
BRZ_88 (06-06-2020)
JDL 4-1 dyno results CSG Mike Engine, Exhaust, Transmission 41 12-18-2019 11:05 AM
My Nameless header dyno results (results to follow) Simply_the_best Engine, Exhaust, Transmission 39 06-28-2016 04:09 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
