Old 05-28-2020, 09:44 AM   #1
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
Bad design, or bad luck?
After my air conditioning recently failed in my '18 BRZ, I brought it to the dealer for a warranty repair. The dealer notified me that the A/C condenser had a huge hole in it, likely from road debris, and would not be covered under warranty. Given that the car is relatively new, I'm mulling some options for repair as A/C will be essential for me in the DC summers. Has anyone else ever has this issue on their BRZs especially the '17+ models? Should I chalk it up to bad luck and move on? Let me know your thoughts.
A/C condenser damage
iff2mastamatt is offline   Reply With Quote
Old 05-28-2020, 10:02 AM   #2
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Those usually hit my windshield.
NWFRS is offline   Reply With Quote
Old 05-28-2020, 10:04 AM   #3
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
It's bad luck...good news is if you are mechanically inclined you can replace the condenser and recharge the A/C yourself pretty easily and cheaply. Most auto part stores loan the vacuum pump and A/C gauges for free.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following User Says Thank You to Opie For This Useful Post:
p1l0t (05-28-2020)
Old 05-28-2020, 10:10 AM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Wow. Do you have a grill?
DarkPira7e (05-28-2020), p1l0t (05-28-2020)
Old 05-28-2020, 10:19 AM   #5
iff2mastamatt
Feeling Iffy?
I appreciate the suggestion, as the repair quotes seem to be around $750-$1000 around my area. The part is about $160 but most labor rates run $150 per hour around here.
Yes, you can see it in the image url. I'm considering adding some zip ties to prevent this from happening again.
Old 05-28-2020, 11:03 AM   #6
Opie
Opie's Avatar
You can get a new TYC Condenser on Amazon for around $90 (new Subaru Condenser is $360), 16oz can of R134a refridgerant is around $20, loan the A/C equipment will result in $110 in parts, removing, replacing and recharging the A/C will take you 2-4 hours and save you $640-$890.
If you were closer I'd do it for you for $100 if you bought the parts.
Good video's for what to do after you've replaced the condenser:
Pulling a vacuum to remove moisture and air from the system prior to recharging it
Recharging using a can of freon:
FRS/BRZ requires 12oz (+/-1oz)
Code Monkey (05-28-2020)
Old 05-28-2020, 11:03 AM   #7
p1l0t
p1l0t's Avatar
Yeah that sucks. It's something easy enough to watch a quick youTube video and replace though I imagine. If it's anything like the WRX you only need like a flat head and a socket wrench to do the whole job. EDIT: oops I guess a compressor is a little different than a radiator haha.
Old 05-28-2020, 12:02 PM   #8
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
There's really no such thing as bad luck. But there is Shit Happens.
This is Not a common occurrence. My FRS has been round trip across the USA 5 times with no such problem...but I do have plenty of nicks, scratches and lost paint due to flying objects, including rocks thrown by Nebraska State Lawn mowing equipment (roof damage), tiny pieces of pebbles caught in wiper blades (locally behind an open semi-trailer in the rain) which caused scratched windshield. Just keep looking forward in life....
It won't Buff Out, but it's not Totaled either.
>All should be covered by collision insurance. You just must pay the deductible.<
>If your collision deductible is $500 or less, probably best to call your insurance company.<
As shown in videos above you need special equipment in order to evacuate the system even if you can replace the condenser yourself. There's probably an additional part needing replacement...a desiccant, which would be within an a/c receiver-drier or accumulator.
ToySub1946 is offline   Reply With Quote
The Following 2 Users Say Thank You to ToySub1946 For This Useful Post:
Opie (05-28-2020), thomasmryan (06-15-2020)
Old 05-28-2020, 12:22 PM   #9
Opie
Opie's Avatar
This is true, insurance will cover it...less your deductible.
Old 05-28-2020, 03:53 PM   #10
p1l0t
p1l0t's Avatar
And then jack your rates for 5 years because you filed a claim...
Opie (05-28-2020)
Old 05-28-2020, 04:23 PM   #11
evomike
Drives: frs
this would fall under a comp claim if reported correctly
evomike is offline   Reply With Quote
Old 05-28-2020, 04:24 PM   #12
If you can say it was moving and hit you then it would be comprehensive and (usually) won't affect your rates. Pretty hard to make a convincing case in these circumstances though.
Old 05-28-2020, 04:41 PM   #13
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Only if the rock was moving when you hit it.
And they will still jack your rates for 5 years for a comp claim.
Sorry, I meant 'you won't be eligible for a few discounts'.
Old 05-28-2020, 04:45 PM   #14
Opie
Opie's Avatar
Stick an arrow in it and tell them you found it that way...
p1l0t (06-11-2020)
2018, bumper, condenser, radiator
Bad Luck With My BRZ. FT911 BRZ First-Gen (2012+) — General Topics 45 12-23-2014 11:48 AM
Bad luck! :( Beeboo4life Scion FR-S / Toyota 86 GT86 General Forum 45 04-25-2014 08:37 PM
Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 58 04-11-2011 09:03 PM
