Old 05-27-2020, 05:55 PM   #1
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
P0332 Knock Sensor 2 Circuit Low Input (Bank2)
Does anyone know where this sensor is located? I am going to pull it out and run some tests on it, possibly buy a new one.
Thanks
Old 05-27-2020, 11:14 PM   #2
tomm.brz
Drives: brz 2017 hksv2
they are on engine block under the intake manifold
Old 05-28-2020, 08:00 PM   #3
B-R-Z
B-R-Z's Avatar
Ah, that sucks.
Old 05-28-2020, 08:20 PM   #4
B-R-Z
B-R-Z's Avatar
Is there any way to tell which is which? Was planning on replacing #2 only.
Just looked under the hood and was able to spot both sensors. The one on the drivers side will be relatively easy to get to without removing the manifold. The passenger side one looks accessible as well, but will be more of a PITA.
Old 05-29-2020, 03:49 AM   #5
tomm.brz
don t take it as totally true because i don't know
i would think knock sensor #1 in one on the left on that photo
if you reahc them you could unplug one and see the dtc
p0327 /0328 would be for sensor 1
p0332 /0333 sensor 2
Old 05-29-2020, 10:57 PM   #6
B-R-Z
B-R-Z's Avatar
Yeah I'll try that. Praying it's the easier to reach on that is bad.
Old 05-30-2020, 05:21 PM   #7
B-R-Z
B-R-Z's Avatar
I was able to get the sensor off without taking off the manifold. I had to buy a long low profile ratchet swivel wrench from harbor freight which was perfect for this sensor.
I powered up the ECU with the sensor disconnected and confirmed the driver-side sensor is knock sensor 2 since I got P0333 Knock Sensor 2 Circuit High Input (Bank 2).
I did some tests using a multi-meter and found the battery is expired so I need to repeat this process when I get a new battery. My main battery voltage was reading inconsistently so I'm not sure how much I can trust any of these results.
I read that I am supposed to see 5 volts going to the sensor. I connected the positive lead of the multi-meter to the plug from the car and negative to ground and got a 3.19 reading.
Old 06-30-2020, 04:39 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Curious if your CEL was resolved by a new battery? Or did you replace the sensor itself? I just got P0327 (same condition, other side) a few minutes ago.. Coincidentally, I just replaced my original battery just a few weeks ago with a nice new AGM Miata battery from East Penn/Deka. No issues with cranking the car up, even after sitting for days, but the CEL just popped on as I was cruising along at 30mph or so. I cleared it, but it came right back..
I might put a battery tender on the car tonight, then clear the CEL and see if it comes back...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 07-10-2020, 11:10 PM   #9
B-R-Z
B-R-Z's Avatar
I had the code around when I created the thread, I cleared it and was fine for 1-2 weeks and it eventually came back. I cleared it again but it kept coming back and the car was running like crap. This is when I removed it, did some multi-meter testing on it, then put it back in. It's been fine since.. knock on wood. Maybe the connector was loose or had some gunk in it causing a voltage drop.
Meanwhile I ordered 2 nice looking used ones on ebay for a good price for when and if the code comes back.
I replaced my batter in January 2018 so it's unrelated to my code.
Old 07-14-2020, 12:57 PM   #10
venturaII
venturaII's Avatar
Originally Posted by B-R-Z View Post
Interesting. After I swapped the battery for the smaller Miata unit, I'd been doing just quick 5 minute errand driving for the week or so prior to the code, plus I've been working from home so the car stays parked for days on end. I cleared the code, rechecked the connections on my terminals, and put a battery tender on the car overnight, and voila - no more code. If this is because of the smaller battery, I might need to hard wire a battery tender pigtail and have it sticking out the front grille for when colder weather comes..
Knock Sensor Control Logic ztan Software Tuning 9 07-04-2024 03:29 PM
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
Anyone ever seen this CEL? P0327 Knock sensor. xkalelx Issues | Warranty | Recalls / TSB 2 02-08-2016 06:20 PM
P0102 Mass or Volume Air Flow Circuit Low Input blackfireball5 Issues | Warranty | Recalls / TSB 2 12-20-2014 01:33 PM
Active Knock sensor Fat Spider Engine, Exhaust, Transmission 13 07-14-2013 08:37 PM
