Old 05-27-2020, 01:14 PM   #1
junpuff
Drives: '13 subaru brz
Maintenance Cost of AT Extension Housing Seal Replacement
2013 Subaru w/ 73k miles
Transmission Extension Housing Seal (P/N 17009AA020) leak
Dealership quoted $281 to replace the seal and reseal housing (~3 hours?), is this reasonable? I called an independent repair shop and they also quoted me $280-$320 off the top of their head with no visuals.
Sorry for the noob question (I searched the forums and only 2 topics came up that were both covered under warranty). Thanks in advance!
junpuff is offline   Reply With Quote
Old 05-27-2020, 01:51 PM   #2
86TOYO2k17
Drives: 2017 toyota 86
I did this job myself. It is pretty easy to DIY, remove driveshaft, get the seal puller pull out seal, i used a pvc pipe from home depot and rubber mallet to pop her back in. hardest part is locating the correct seal puller, with that tool it should be about 2 hours from putting on jacks to off jacks. Obviously a lot of shops add another hour or so to jobs for any issues/ to make more money, so 3 hour quote isn't unreasonable.
Old 05-28-2020, 07:15 PM   #3
junpuff
Ohhh that's good to know. It seems straight forward from the service manual but I have no experience with cars hah. Thank you!!
The Following User Says Thank You to junpuff For This Useful Post:
humfrz (05-29-2020)
Old 05-29-2020, 03:24 PM   #4
humfrz
Well, in that case, the price you were quoted is reasonable -
Or, if you're over 75 years old, it's reasonable.
Front windshield replacement cost RAWR BRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 87 04-18-2019 10:16 AM
Burnt Fuse Housing Replacement? Kordless Electronics | Audio | NAV | Infotainment 0 11-28-2017 04:40 PM
Cost for maintenance is NUTS!! silvercar CANADA 41 04-09-2015 11:38 PM
Fender liner replacement cost? impossible Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 11-01-2014 08:48 PM
Cost of maintenance cys19 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 09-22-2014 01:50 AM
