Drives: 2014 White BRZ
Transmission Input Shaft
Anyone know how much movement to expect on the manual transmission input shaft? I am working on my hydraulic bearing and noticed the shaft has a bit of play and dont remember it being like that before. I don't find the transmission service manual to be very clear.
#2 | |
Drives: FRS
Got a video? Sent from my iPhone using Tapatalk |
not playing cards
There's some play until it's mounted to the engine. The pilot bearing supports the input shaft, maintaining coaxial alignment with the output.
Drives: BMW M5 e90
Do you have more information?
Sorry for the delay. I have been tied up the last couple days
Not sure how to embed a video so here's a link. It seems worse in the video after I watched it. lol There are no signs of leaks from the seal or any other abnormal noises or symptoms. The transmission service manual only has radial clearance checks for the input shaft to the output shaft. The input shaft bearing check is with the shaft removed and only specifies that there is no abnormal feel in the movement, binds, abnormal noise or loose fit. This really can't be checked unless the shaft is in hand holding the bearing with the shaft. As Ultramaroon indicated once installed it is supported by the pilot bearing. Seeing how I had no other symptoms at this point I think I will install it and monitor. |
not playing cards
It's fine.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | humfrz (05-29-2020), solidsnake11 (05-29-2020) |
Drives: brz
| The Following User Says Thank You to solidsnake11 For This Useful Post: | Ultramaroon (05-29-2020) |
Drives: brz
The input shaft is held by the input bearing and a small ~ 14mm needle bearing. It floats around until it goes in the clutch and pilot bearing.
#10 |
Bubba says, no problem, as long as the oil doesn't puddle up.
| The Following User Says Thank You to humfrz For This Useful Post: | solidsnake11 (05-29-2020) |
#11 |
#12 |
not playing cards
jk it's fucked
#13 |
| Transmission Synchro/Output Shaft Noise After a Concerning Sound | Rybot | Engine, Exhaust, Transmission | 7 | 07-01-2022 11:06 AM |
| Should I let dealer change propeller shaft/transmission. | ItsReiko | Issues | Warranty | Recalls / TSB | 7 | 01-16-2020 08:16 PM |
| Steering rack input shaft - oily / leak? | 1Cor10:23 | Issues | Warranty | Recalls / TSB | 2 | 09-21-2015 04:17 PM |
| Possible Transmission Problem...Input Please | wawawoowee | Issues | Warranty | Recalls / TSB | 11 | 05-24-2015 01:11 PM |
| Transmission selector shaft removal | Nigelr32 | DIY (Do-It-Yourself) Guides | 0 | 12-29-2014 04:34 AM |
