Old 01-16-2020, 04:05 PM   #1
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Should I let dealer change propeller shaft/transmission.
Hey guys. The dealer wants to do some major work on my car and I wanted to get some of your opinions. So here is the backstory:
I went in initially for a simple battery check since my car dies very easily and I thought my alternator was bad and they said the battery test failed. Easy fix, they can just change the battery for me. But since I was already there, I mentioned there being a small pop noise I hear in the rear of the car every time I back out of my driveway in the cold mornings. I thought it was something with the suspension so I told them that.
1 day later I checked in to see if the car was ready for pickup and I was told that they did a test drive and found the noise to be caused by the propeller shaft and transmission mounts, which was super surprising to me. Fast forward to today, the car has been at the dealer for 3 weeks coming up to 4, and I'm being told by my service rep that my propeller shaft may have been bent, I have no idea how and they finally got the parts but it will be a two day job. I thought propeller shafts are super easy to switch out or am I wrong? And if changing it does not fix the problem they may have to replace my transmission.
Now this has gotten way more serious than I have intended to go in for and have no idea how they diagnosed a sound I heard from the rear of the car all the way to changing the transmission. Would you guys just let them do all this work or would it be smarter to leave it the way it is if I don't believe there's anything wrong with it? This is all under warranty. And my car is only a 2017 with 25k miles..
Thanks for reading.
Sent from my SM-G9600 using Tapatalk
ItsReiko is offline   Reply With Quote
Old 01-16-2020, 04:20 PM   #2
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
If it's under warranty just let them finish it. Maybe the original shaft was one of those cancer-causing units....
NWFRS is offline   Reply With Quote
Old 01-16-2020, 04:43 PM   #3
Lantanafrs2
Drives: 2013 frs red
My car has an occasional popping sound when backing out of driveway. It's done it for 6 yrs though. Probably suspension and axle slightly disagreeing
Old 01-16-2020, 04:57 PM   #4
ItsReiko
ItsReiko's Avatar
Does it happen when your clutch first engages with a little bit of gas?
Old 01-16-2020, 05:52 PM   #5
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
yep I get it too, along with thousands of other noises...personally I just think it is another clunk to live with, who cares most situations involving "i hear something weird" + having the dealer diagnose & solve usually don't go well.. otherwise you'll be going down the rabbit hole if you start chasing noises on this platform
HKz is offline   Reply With Quote
Old 01-16-2020, 05:53 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Let them do anything and everything they want. Now you have ammo if anything ever goes wrong with anything they touched. Priceless.
Old 01-16-2020, 07:25 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
encourage them to change the struts, and the brakes, just in case.
Old 01-16-2020, 08:16 PM   #8
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
I could see how a bent prop shaft could eff the transmission since it would essentially be shaking things up.
But a bent propshaft would be giving you symptoms driving at speed, not just slowly backing out. Maybe if it was a bad u-joint? Not sure.
I guess if it's all being covered under warranty let them do it, so long as you trust their work. I would ask for a thorough explanation of how they came to their conclusions.
It does sound like you are their lowest priority given how long they have been taking. Removal and replacement does not take long, so multiple days doesn't make sense unless they need to wait for parts to be delivered.
Anyway, if they keep dragging their feet just call every day for an update until they get the hint.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Transmission Synchro/Output Shaft Noise After a Concerning Sound Rybot Engine, Exhaust, Transmission 7 07-01-2022 11:06 AM
Transmission selector shaft removal Nigelr32 DIY (Do-It-Yourself) Guides 0 12-29-2014 04:34 AM
Help with Oil change at dealer kombatlion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-23-2013 10:54 AM
should i change oil myself or let dealer do it? chenshuo CANADA 28 02-14-2013 01:28 PM
Dealer Oil Change JSK CANADA 6 10-05-2012 04:36 PM
