Old 05-27-2020, 12:43 AM   #1
RWD fun
AC leak?
I noticed a weird chirping noise while driving on the highway today, it went away after a few minutes, I pulled over for gas shortly after and checked around to see if there were any obvious culprits. There was a fluid on the low pressure AC line, and a little pooled in the metal fitting. I'm curious, how hard is this to fix, and can I short term fix it with electrical tape heavily wrapped around it?
RWD fun is offline   Reply With Quote
Old 05-27-2020, 01:33 AM   #2
humfrz
First off, I'd suggest you wipe the fluid off and see if it comes back.
If it does, I'd suggest you take it into a auto shop that does AC work and have them take a look it it. Maybe they will just replace the line and re-charge the system.
As far as "fixing" it with electrical tape, even Bubba doesn't think that would hold long.
Old 05-27-2020, 01:42 AM   #3
RWD fun
Definitely. I'll have to wait and see.
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 09:40 AM
Eek! Oil leak Qwimby1 Engine, Exhaust, Transmission 12 04-11-2019 03:40 PM
Oil Leak Brz_racer Engine, Exhaust, Transmission 22 07-17-2017 04:28 PM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 07:08 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 08:40 AM
