Old 05-23-2020, 12:34 PM   #1
kuchez96
Drives: 2025 Subaru BRZ
Flex Fuel for 2017+ models
Hey guys, I recently started to look into getting E85 for my 2019 BRZ and I am unsure of which direction to go and what exactly I need.
Firstly, I'd like to say I prefer going the OFT route with their kit so I can reflash to stock tune on the spot and use OTS tunes. However, I do not know if their kit is compatible with 2017+ models.
Second, the ECUTeK route. I've gotten a lot of feedback on this route and people say it is the best route. If I were to go this route, what would be the best kit to get, does it come with a tune, are there multiple maps I can use/ OTS tunes, do I need to pay for tunes anytime I want to retune?
2019 BRZ with Remark Muffler Delete and plan on getting a Tomei UEL.
kuchez96 is offline   Reply With Quote
The Following User Says Thank You to kuchez96 For This Useful Post:
Windycitystig (07-05-2020)
Old 05-23-2020, 08:59 PM   #2
dpfarr
Drives: BRZ ts
I’ve been reading into this too. Can the fuel system (pump, lines, etc.) handle E85 no problem?
dpfarr is offline   Reply With Quote
Old 05-23-2020, 09:45 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yes
Old 05-24-2020, 12:04 AM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The fuel system is already handling ethanol. Pump gas is E10.
For basic bolt ons, the stock fuel system should be fine. For basic FI, injectors are advised, but not necessary. For high boost pulleys, injectors are needed, and it is worth dropping in a better fuel pump.
For ECUTEK, you need a license ($350+), a bluetooth interface/cable and dongle ($350+) and a flex-fuel tune ($350+). If you add a new performance product then you need a new tune, which means paying for an upgrade ($75-350). It all depends on your tuner. The advantage is that the ECUTEK is a far superior custom tune.
OFT is cheaper.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Plumbus (12-29-2020)
Old 05-24-2020, 11:38 AM   #5
dpfarr
Drives: BRZ ts
Right on. Will figure out what I need to bolt on before I get to a tune.
Old 05-24-2020, 11:57 AM   #6
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
You can flash back to a stock rom using ecutek as easily as you can with oft. Pick your Ecutek tuner (HRI, Delicious Tuning, Xero Limit, CSG) and then buy their tune package which will come with an Ecutek dongle/cable + Ecutek license and then they’ll remotely tune your car. A header + custom to your car ecutek tune is about the best mod combo to this platform besides tires and seat time at a track.
If you want to go E85 you’ll need a flex fuel kit with the above and your tune will auto read the ethanol content in the gas and adjust automatically without needing to switch maps.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 05-24-2020, 03:56 PM   #7
dakine001
Drives: 17 BRZ PP
I have a 2017 with CSG’s flex fuel kit and tune (Ecutek) and love it. Recently added JDL’s UEL header (with updated tune) and like everybody says, it’s the way to go. I was planning on going FI, but I’m pretty happy with this setup-for now.
dakine001 is offline   Reply With Quote
Old 05-24-2020, 04:34 PM   #8
dpfarr
Drives: BRZ ts
What other mods do you have in addition to headers? Is there difference between monitors to control AFR?
Old 05-24-2020, 05:01 PM   #9
dakine001
Drives: 17 BRZ PP
Just an ARK catback, I thought about up pipe and front pipes, but want to keep the noise level down since I’m in CA. Not sure about monitors to control AFR.
Old 05-30-2020, 05:14 PM   #10
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We also have our combo here: https://www.xero-limit.com/ecutek-bl...l-package.html
With that pricing you're right there at the cost of an OFT+flex fuel kit, but get all the advanced features and custom tuning you get with EcuTek.
Otherwise there's been no issues running e85 from our end since we've been doing it in 2013, I wouldn't fear it!
Xero-Limit is offline   Reply With Quote
The Following 3 Users Say Thank You to Xero-Limit For This Useful Post:
alphasaur (05-30-2020), Jyn (06-20-2020), Windycitystig (08-31-2020)
Old 06-20-2020, 08:58 PM   #11
tom@ptuning
tom@ptuning's Avatar
Drives: 2013 Scion FRS
The flex fuel kit would be our PTUNING flex fuel kit that CSG sells. Only place you are able to get our flex fuel kit is ourselves and CounterSpace
tom@ptuning is offline   Reply With Quote
Old 06-25-2020, 05:29 PM   #12
PenGun
Drives: Red 2019 Subaru BRZ
What are we looking at for power increase? The same compression, so all we can have is what the computer lets us have, I assume.
I have 94 octane pure gas here and it works very well.
PenGun is offline   Reply With Quote
Old 06-25-2020, 05:31 PM   #13
tom@ptuning
On my NA car I see a 20whp difference and on my supercharged car there is a 50~whp difference at the same boost level
Sent from my SM-G960U using Tapatalk
The Following User Says Thank You to tom@ptuning For This Useful Post:
tomm.brz (06-25-2020)
Old 06-25-2020, 07:46 PM   #14
Misfire
Misfire's Avatar
Drives: 2017 Series.Yellow, 2005 LGT wagon
Have you guys figured out the display module freezing on boot at high ambient temperature? I've called numerous times and spoke to a handful of people at PTUNING over the past couple of years (not yet this year though, its only locked up a few times so far), and it was always "going to be looked into," but I never heard anything back.
I love the kit, the flex module works 100% of the time, and I can still access it via bluetooth even if the display module freezes up. Its just a minor annoyance.
Misfire is offline   Reply With Quote
2017+, e85, ecutek, flex fuel, oft
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
Flex Fuel 2017/"86 RUNNING?? 007BRZ Forced Induction 6 09-25-2017 03:01 PM
Cost effecient (cheap) flex fuel kit to get up and running on E85 for 2017 BRZs? GNious Software Tuning 4 02-06-2017 05:22 PM
Delicious Tuning Flex Fuel for 2017+ Updated to Accommodate Manufacturer Revisions DeliciousTuning Software Tuning 0 01-04-2017 02:24 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
