Old 05-21-2020, 03:56 AM   #1
jmai
jmai's Avatar
Drives: 2019 PP BRZ
Jackson Racing NA Oil Cooler
So I ended buying a used JR NA oil cooler and was wondering if there was suppose to be any included hardware that mounts the bracket to the bumper or does it just reuse the oem bolts on the bumper.
jmai is offline   Reply With Quote
Old 05-21-2020, 05:14 PM   #2
It mounts onto your impact beam.
Old 05-21-2020, 06:30 PM   #3
Joon525
Joon525's Avatar
Drives: 2016 BRZ
He's asking if the NA oil cooler is supposed to come with hardware....
@jmai this is a link to the installation manual.
https://jacksonracing.com/pdf/instru...anual_rev2.pdf
The bottom of page 2 states
Part Numbers will be listed throughout the installation instructions in parentheses.
(1234-56-789) or (12345-67890)
An example is in the middle of page 8.
22. On the driver side of the front bumper support you will find an open mounting hole with no
threads that is approximately 23” from the stud mounting location. Reach in through the opening
in the front bumper support and install a M6x1.0x25mm flanged bolt (91100-06025) with a M6
fender washer down through this mounting hole
So yes, I would assume this unit came with hardware.
Joon525 is offline   Reply With Quote
Old 05-21-2020, 09:50 PM   #4
jmai
jmai's Avatar
Drives: 2019 PP BRZ
Sorry I meant the hardware to mount onto the impact beam. Doesn’t seem like the person I bought it from had hardware to mount it or does it uses bolts that already exist on the impact beam
Old 05-21-2020, 09:51 PM   #5
jmai
jmai's Avatar
Drives: 2019 PP BRZ
That’s what I was curious about, but doesn’t seem like it shows any hardware on the website images
Old 05-22-2020, 09:42 AM   #6
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Even though the pictures don't show hardware it doesn't mean it's not required. No one should expect the core to mount itself by means of magic. The pictures are just for marketing purposes. So...
  • Read the manual I linked you to and buy the same hardware at a local store.
  • Contact Jackson Racing and see if you can buy the hardware from them.
  • Contact the guy you bought it from and ask if they have the hardware.
Old 05-22-2020, 01:04 PM   #7
Used items are rarely complete. You'll need to source replacement hardware. If the uninstall was incomplete, then I would recommend carefully inspecting the rest of your used oil cooler.
Spuds (05-22-2020)
TRD and jackson racing oil cooler V1 FR-Sky Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 05-10-2019 01:45 AM
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
FS: Jackson Racing Oil Cooler Cop Engine, Exhaust, Bolt-Ons 8 06-27-2016 01:39 AM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 11:04 AM
