Old 05-17-2020, 12:35 PM   #1
moda3
moda3's Avatar
Drives: FR-S RS 2.0
Help needed with Smartkey customization (2016 model)
So..
When if I press the "lock" and "unlock" button of my smartkey for 10 seconds, it chirps twice and beeps from the outside once. If I continue holding down the two buttons (without letting it go from the first place), then after 10 seconds I hear two chirps and two beeps from the outside. If I continue holding down even longer it will cycle though 1 beep and 2 beeps.
I know some setting is cycling through but I have no idea what is changing. It is not the passenger unlock setting for sure.
Does anyone know what this could be changing??
Also, I hear 2 different stories about "autolock" when you leave the car. Does it lock automatically or no?
Lastly, was there any more hidden feature found besides what is listed here?
Any advice will help.
I try searching the forum before asking but its kinda hard to sniff through all the threads.
Thanks
moda3 is offline   Reply With Quote
Old 05-17-2020, 12:56 PM   #2
No idea what you are cycling but it is probably the items found on page 373 of the OWNER MANUAL
The "auto lock system only is if you unlock a door with a remote but don't actually open it. It does not autolock after leaving the car for 60 seconds.
If you don't have an owner manual here it is. Read and discover a whole bunch of things.
https://www.toyota.com/t3Portal/docu...f/OM18056U.pdf
Old 05-17-2020, 01:22 PM   #3
moda3
moda3's Avatar
Drives: FR-S RS 2.0
Thanks for the input.
I read the owner's manual back 2 back and yes I feel like you are maybe right but I just can't tell which one is cycling..
Anyone else know what is happening?
Old 05-20-2020, 08:32 PM   #4
moda3
moda3's Avatar
Drives: FR-S RS 2.0
bumpee
Old 05-20-2020, 08:56 PM   #5
moda3
moda3's Avatar
Drives: FR-S RS 2.0
nvmnd. figured it out.
it cycles the option to unlock passenger door when proximity is triggered.
Older model parts fit 2016? JPRodney Scion FR-S / Toyota 86 GT86 General Forum 7 04-27-2016 01:59 PM
2016 Model still rattle on the rear deck ? xtral Issues | Warranty | Recalls / TSB 22 08-31-2015 03:59 AM
2013 FRS 10 Series / BRZ Smartkey REMOTE START Dustin2JZ Scion FR-S / Toyota 86 GT86 General Forum 35 03-18-2015 10:18 PM
