Old 05-08-2020, 08:34 PM   #1
turboencabulatr
turboencabulatr's Avatar
Drives: 2013 brz redheaded stepchild
Deleted
Deleted
Last edited by turboencabulatr; 05-15-2022 at 03:06 PM. Reason: Incorrect information
turboencabulatr is offline   Reply With Quote
Old 05-08-2020, 10:22 PM   #2
humfrz
Are you sure the steering wheel itself hasn't slipped on the steering spline it is attached to?
(or am I stuck in the 50s - again?)
Old 05-09-2020, 12:42 PM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by turboencabulatr View Post
I have a strange one.
I was drifting with lots of spinning out and the steering wheel is now cocked at a 45deg angle when driving straight. The kicker is that nothing is wrong with the suspension, tie rods, rack, rack mounting or U joint. I checked them all thoroughly. Wheels are perfectly parallel, steering is smooth and tight. Trust me, I used to be a legit mechanic but before EPS was a thing.
The only thing this can be is the electric power steering gear system is misaligned. The darn factory manual is useless as far as this goes. They don't show a digram of the EPS because it is not disassembled by dealers ever apparently.
I just want know if this is something that can be realigned mechanically using a scan tool at the dealer or do I have to replace the whole assembly?
THX
An electronic power steering doesn't really get "misaligned", because it isn't "aligned". The steering wheel has a hard physical connection to the steering rack, there are BEEFY splines all over, that junk is not going to slip, that is the part that is aligned, the EPS is a helper motor on the steering shaft and uses a torque sensor and a VSS value over CANBUS to know how much help to give and isn't really concerned with where the center is (it knows, and it's probably taken into account, but in the grand scheme of things, isn't a big factor)
What IS concerned with the steering wheel position is the Stability Control, and that has a big sensor right behind the steering wheel to know where you're steering, Accessing the EPS datastream with a scan tool, you'll be able to see if the 0 degree position is still in the middle, I suspect it is.
Maybe I'll surprise you, but the ass end of the car has just as much influence on the steering center as the front. Check your thrust angle.
Old 05-09-2020, 01:49 PM   #4
turboencabulatr
Old 05-09-2020, 01:54 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Wheel alignment?
Old 05-09-2020, 02:26 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
it really sounds like a steering wheel issue, and not a car issue
i believe the car measures steering angle at the steering box, so the only point of reference that's changed is your point of reference. the steering wheel.
more importantly, where did it change. i would first pull the steering wheel to look for damaged splines from the wheel slipping. after that, i'm suspicious of the steering rack jumping teeth, considering that you've said the stock wheel size now over-turns and rubs in the 1 direction.
Old 05-09-2020, 06:12 PM   #7
RZNT4R
Wait wait wait what.
The kicker is that nothing is wrong with the suspension, tie rods, rack, rack mounting or U joint. I checked them all thoroughly. Wheels are perfectly parallel, steering is smooth and tight. Trust me...
I'm quite sure it's a front end issue. The stock size wheel seriously rubs on the LH inner wheel well when turning. When parked if you straighten the steering wheel the front wheels are both significantly turned. The trac control, ABS and brake MILs turn on as soon as i drive a few hundred feet.
I mean hey, just fuck everything right, check it all thoroughly and it's fine but it rubs but that's probably fine but maybe not, the whole dash is lighting up! Send it anyway lol
Bring
it
to
a
shop
Old 05-09-2020, 07:10 PM   #8
ls1ac
ls1ac's Avatar
Got to love it: Everything is fine, I checked it. Only steering wheel has to be 45 to go strait. tire rubs when turning and lots of warning lights.
Absolutely you need a pro. Run do not walk to a dealer.
You can not magically mechanically realign with an electronic scan too.
Old 05-09-2020, 07:16 PM   #9
RZNT4R
You totally can, you plug it in and double click Align.exe and that shit takes care of itself, it unbends with the power of electrons, which is the strongest power btw.
Old 05-09-2020, 08:02 PM   #10
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
If there was no impact, and no suspension parts are broken, sloppy or deformed, it is probably something electronic. Then again, the rubbing is a concern. In that case, your dealer should have ability to pin point and repair the issue. Please let us know how it resolves...
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 05-11-2020, 08:34 AM   #11
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Something in your front end is wrong...wheel should never rub. Bent, broken or loose. Not an EPS issue.
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 05-11-2020, 02:18 PM   #12
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Not 100% sure on the body of these cars, but a generic possibility would be that the subframe shifted.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Electric Power Steering (EPS) noisy RevoG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 144 10-01-2023 03:25 PM
Recall for Electric power steering (EPS) tm86 AFRICA 36 05-16-2017 07:04 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 08:19 AM
Toning down the electric steering pump possible? kertong BRZ First-Gen (2012+) — General Topics 18 03-03-2013 12:51 PM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
