Old 05-06-2020, 01:53 PM   #1
raz.sofer
raz.sofer's Avatar
Drives: Subaru BRZ 2015
10mm spacers on arp standard length studs
Hi.
I got a set of 2 spaces for my rear wheels (17x9 +38)
I have been running 5mm's for a few months now, drift, track - no issues.
Got the 10mm's to poke the wheels more (didn't install them yet). I understood I can't use them with my studs.
I have looked at the ARP extended and have read that they are good for this spacer. My problem is I don't like the look of open end lugs and would like too keep my lugs (RAYS L42). Is that possible? If not, is there a closed lug that would fit?
Thank you for your help in advance!
raz.sofer is offline   Reply With Quote
Old 05-06-2020, 02:39 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
At the very least you'd want the 1.95" ARP studs. They're only 5mm longer
I order 2.5" ARP studs for 10mm spacer and ordered gorilla long close ended nuts.
Old 05-06-2020, 04:03 PM   #3
raz.sofer
raz.sofer's Avatar
Right now I have the 7727
Can you check which gorilla kit do you have for me please? because I saw a few options not just one.
Basically I’m limited only because of the lug nuts
Old 05-06-2020, 04:27 PM   #4
RToyo86
RToyo86's Avatar
Gorilla 45128BC-20
Not sure about other color options, but that is what I ordered.
FS: B2 10mm spacers+studs (4), MN Nate. Wheels and Tires 2 03-05-2016 08:31 PM
B2 Auto 10mm HubCen Spacers + Studs BNIB BDotG Wheels and Tires 6 12-16-2015 11:50 AM
Ichiba 10mm hubcentric spacers with extended studs protpibe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-01-2015 03:21 PM
Eibach Sport Pro Springs, 10mm/5mm Hub centric Spacers, Ichiba extended studs bryan767 Brakes, Suspension, Chassis 9 04-26-2015 07:40 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
