| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Subaru BRZ 2015
10mm spacers on arp standard length studs
Hi.
I got a set of 2 spaces for my rear wheels (17x9 +38) I have been running 5mm's for a few months now, drift, track - no issues. Got the 10mm's to poke the wheels more (didn't install them yet). I understood I can't use them with my studs. I have looked at the ARP extended and have read that they are good for this spacer. My problem is I don't like the look of open end lugs and would like too keep my lugs (RAYS L42). Is that possible? If not, is there a closed lug that would fit? Thank you for your help in advance!
#2 |
Drives: 17 Asphalt 86
At the very least you'd want the 1.95" ARP studs. They're only 5mm longer
I order 2.5" ARP studs for 10mm spacer and ordered gorilla long close ended nuts. |
#3 | |
Right now I have the 7727 Can you check which gorilla kit do you have for me please? because I saw a few options not just one. ![]() ![]() Basically I’m limited only because of the lug nuts Sent from my iPhone using Tapatalk
#4 | |
Not sure about other color options, but that is what I ordered. |
| FS: B2 10mm spacers+studs (4), MN | Nate. | Wheels and Tires | 2 | 03-05-2016 08:31 PM |
| B2 Auto 10mm HubCen Spacers + Studs BNIB | BDotG | Wheels and Tires | 6 | 12-16-2015 11:50 AM |
| Ichiba 10mm hubcentric spacers with extended studs | protpibe | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-01-2015 03:21 PM |
| Eibach Sport Pro Springs, 10mm/5mm Hub centric Spacers, Ichiba extended studs | bryan767 | Brakes, Suspension, Chassis | 9 | 04-26-2015 07:40 PM |
| ARP Wheel studs and 10mm hubcentric wheel spacers | S1CNSTY_SUBIE | Wheels and Tires | 3 | 04-17-2015 08:31 AM |
