Old 05-04-2020, 10:04 PM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
Weird pop in steering
This doesn't happen when its less than or equal to about 80F outside but when its above that temp. whenever i'm turning the wheel a large amount to the left or right I can hear a pop. like something was in the way but the pressure released. Is this normal, I can record it if need be.
dholloway543 is offline   Reply With Quote
Old 05-04-2020, 11:07 PM   #2
anticubus
Drives: 2017 Toyota 86
Pretty much guaranteed to be something loose in the suspension or steering. What kind of loose will be hard to say.
I'd start with checking lug nut torque, move to sway bar links, followed by outer and inner tie rods, then ball joints, CV joints, and the bolts holding your struts/coilovers to the strut tower.
It's best to do this with the suspension entirely unloaded and the strut/coilover disconnected from the knuckle. Sway bar links, tie rod inners and outers, and ball joints should not be easy to move by hand, but they should also not be frozen. CV joints should hold position but not bind. Strut tower bolts should be checked with a small torque wrench (Usually inch-lb rates, don't know the spec off-hand.)
After going through all that diagnosis effort, I'd be posting this same thread and making a stop at my preferred wheel and alignment shop. Lots of members here can offer more experience than I can.
anticubus is offline   Reply With Quote
Old 05-06-2020, 12:44 AM   #3
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Did this issue arise after installing new suspension components? A similar issue for me after installing new springs.
ItsReiko is offline   Reply With Quote
Old 05-06-2020, 07:59 AM   #4
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
My pop is when going lock to lock (but the pop always comes from passenger front) or sitting at 3/4 of the way to lock while backing out of a driveway. I've taken the endlinks off momentarily, and it made no difference. I'm headed to a shop Saturday for a professional diagnosis.
MCTeeJ is offline   Reply With Quote
Old 05-06-2020, 12:36 PM   #5
radroach
Drives: car
@dholloway543 On some mornings I get a pop in my steering when I back out of my parking space and turn my wheels to the left. Almost feels like my wheel is running over a rock. I figure its my brakes dragging.
Old 05-06-2020, 01:54 PM   #6
dholloway543
Software Hobbiest
Drives: 2015 FRS
If there are more than a handful of cases its probably just a feature not an issue
Old 05-11-2020, 03:34 PM   #7
dholloway543
Software Hobbiest
Drives: 2015 FRS
I have a feeling that its the tophat bearings binding. Ill look into it farther though.
Old 05-11-2020, 05:34 PM   #8
pogofx
Drives: 2018 BRZ Limited
My top hats (upper strut mounts) pop doing the same kinda stuff. Usually low speed turns backing out of the driveway or into or out of a parking spot. Really irritating. I dropped the strut and reinstalled and it seemed to go away for a while, but came right back. I've retorqued everything a bunch of times with no help. Even changed out the sway bar outer end links to adjustable ones when I thought that's where it was coming from.
It took me a long time to track it down to the top hats, but I'm confident now that's where its at. I opened the hood and had my wife slowly back the car out of the driveway while I walked along side and place my hand on the top hat. I could feel it right there when it popped as she was turning. Finally the smoking gun to my noise.
I'll be changing them out to Pedders strut mounts over the next few days. Hoping that takes care of it. I am on Eibach Pro springs (TRD's) as well so the may have been a contributing factor.
pogofx is offline   Reply With Quote
Old 05-29-2020, 10:47 PM   #9
dholloway543
Software Hobbiest
Drives: 2015 FRS
NVM turns out this issue was actually my motor mounts being blown. Also the popping during turning was my skid plate shifting, i only had half the bolts in it
Weird white box under steering wheel above pedals. LeftLaner Scion FR-S / Toyota 86 GT86 General Forum 41 11-10-2015 12:32 PM
Weird steering popping. mamamiaellis Issues | Warranty | Recalls / TSB 3 07-16-2015 06:07 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Weird Sound After Coilover Install (when moving steering wheel left and right) taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 07-20-2013 01:18 AM
