Drives: 2018 Gt86
Rear Differential Gear Oil to tune handling balance
Has anyone tried using different gear oil to tune the stock torsen differential? I am wondering if it's having a subtle affect on the corner exit push I sometimes feel. Maybe I should just stop apexing late.
TRACKBREAD
The diff is gear driven, the fluid viscosity or friction modifiers will have negligible effects on the lockup behaviour, that only really works on viscous diffs and clutch diffs.
Can you get more camber?
Edit: yes, the rear diff and factory suspension outgrips the front, imho more front grip is the solution, not less rear lockup. Last edited by strat61caster; 05-03-2020 at 03:36 PM. |
Drives: 16' BRZ
If you want to "tune" your diff you'll need to swap the torsen out for a clutch type LSD.
Drives: 2018 Gt86
Ok. I read a lighter weight oil would increase the locking affect somewhat. Guess not enough to matter.
I do need more front camber. Stock ride height on factory crash bolts doesn't seem to be enough. |
TRACKBREAD
| How does limited slip differential affect handling? | Snoopyjh | Tracking / Autocross / HPDE / Drifting | 11 | 06-01-2018 01:19 PM |
| Motul Gear Competition 75W-140 for differential? | Tor | Tracking / Autocross / HPDE / Drifting | 13 | 09-11-2016 08:01 PM |
| Caution – Differential Gear Oil Equivalent | Daless2 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 23 | 08-18-2015 07:47 PM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| Rear End/Gear/Differential Ratio | fly2low | Engine, Exhaust, Transmission | 9 | 02-09-2013 11:53 AM |
