Drives: 2020 BRZ tS
accelerator pedal for heel-toe downshift
Hi, guys,
I'm looking for an aftermarket accelerator pedal to make heel-toe downshift easy for my 2020 BRZ ts. To me, the OEM gas pedal is located too far and low from the brake pedal. I see products from Cusco, Sparco, etc. Have you tried any of those? Appreciate any input from you. |
Drives: 2017 BRZ Limited PP
I like the Verus Throttle Pedal Spacer kit. Keeps the OEM pedals and is completely reversible. it also allows for adjustments vertically and horizontally. Personally, I prefer it all the way to down and towards the brake pedal.
https://www.verus-engineering.com/sh...z-frs-gt86-380 |
Drives: 2020 BRZ tS
I looked at the link. looks promising. Thanks!
Wes
I’ve been using the SRP pedal for over 3 years now. Quite happy with it plus it’s a 5 minute install. Pull old pedal cover off with pliers, screw in new pedal
Instagram: @gt86ws
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | norcalpb (05-01-2020) |
Drives: jrsc_brz
I have the cusco accel pedal cover, got it before a track day when I had some endless brake stuff coming over from Japan. I dig it a lot. I'd prob get the verus spacer though. The pedal cover is kind of like a bandaid, where the spacer actually fixes the root of the problem. I'm completely satisfied with the cusco pedal cover, dont get me wrong. Makes heal toe a treat.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
Site Moderator
Drives: ichi 86 Project
Those gas pedal spacer work nicely. I have GSpeed (currently different name iirc) pedal spacer and problem for me is it just lifts the pedal too much. I get that, they gotta cover the current bolts, so it won't get in the way. So I just CNC a bit more off the spacer
![]() If it wasn't for the stupid gas/brake pedal mistake issue, we could of had this pedal. ![]() Sadly, I only know 2 ppl have that pedal... and both are AT 86... WHY~ lol If you don't like spacer idea, you can go this option. It cost double or more than some of those pedal spacer. ![]() Cheapest option will be this
Drives: 2014 GT86
BTW, if deciding on GSpeed, suggesting to get Verus one. Spacing wise it's almost completely same + ability for slight adjustment.
Also from my experience if one uses such spacers, is that one shouldn't use also pedal plates that make pedal wider to side (tried Verus + neoplot). Total spacement result gets too close to brake pedal, too easy to mispress together. So imho better choose exclusively, pedal plates OR spacer. @ichitaka05 : i recall in threads about that alternate prelaunch stock pedal, that also some twins in Taiwan may have had it, but couldn't find out how to source from there. Just on 2nd look noticed, that you milled down spacer .. did you also did something to that black puck pedal detent at same time? Last edited by churchx; 05-01-2020 at 03:48 PM. |
#8 | |
Site Moderator
As for pick pedal detent, yes, I had shorten it as well. |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | churchx (05-01-2020) |
| How to Heel Toe Downshift | justinco | Tracking / Autocross / HPDE / Drifting | 3 | 06-04-2018 08:30 PM |
| WTB: Cusco Accelerator Pedal | TiggaPlease | Want-To-Buy Requests | 0 | 05-12-2016 03:35 PM |
| BRZ+ Long legs + heel-toe downshift = fail ? | Breeeep | Tracking / Autocross / HPDE / Drifting | 10 | 10-15-2014 03:25 PM |
| Accelerator Pedal | Blu-by-U | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 03-23-2014 10:59 PM |
| WTB: Cusco Accelerator Pedal | BeRZed | Want-To-Buy Requests | 0 | 03-03-2014 02:12 AM |
