Old 11-13-2017, 01:52 PM   #1
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Arrow How to Heel Toe Downshift
Hey all, I threw this video together over the weekend. It goes over the basics of the heel toe technique, when to use it, why it is beneficial, and then I include demonstrations from both my sim racing rig and in the BRZ. Hopefully this helps some folks who are trying to learn this technique. Let me know if I fudged anything
[ame]http://www.youtube.com/watch?v=xc7HAPDJznI[/ame]
justinco is offline   Reply With Quote
Old 06-04-2018, 06:24 PM   #2
Snoopyjh
Drives: 2014 BRZ Limited
Always appreciate a well put video!
What do you do when you're going over a big speed bump where you have to slow down below 10mph?? Do you downshift into 1st? or just keep the gear in 2nd without clutching?
When i keep it in the 2nd gear, rpm drops down to around 1,500 and i dont think the car likes it (It shakes and vibrates a little until the rpm is around 2,000) Should i bother putting it into 1st? or just keep it in 2nd? I'm not sure if im hurting the car or not
Snoopyjh is offline   Reply With Quote
The Following User Says Thank You to Snoopyjh For This Useful Post:
justinco (06-04-2018)
Old 06-04-2018, 07:52 PM   #3
Grady
Grady's Avatar
Good video. However in your description and on the sim you were brake, gas, clutch. When you were driving your car you were brake, clutch, gas? What sequence is better/correct?
Old 06-04-2018, 08:30 PM   #4
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I put it into 1st if it is slow enough. Just blip the throttle to rev match the 1st gear at slow speeds.
The clutch/gas is kind of simultaneous in real life. But, you don't want to blip the gas without the clutch in, for obvious reasons. On the sim demo I tried to make it super slow mo to make it simple but I think it made it a tad confusing. Brake/Clutch/Gas in short
AT downshift issue FRSBRZGT86FAN Issues | Warranty | Recalls / TSB 92 12-04-2015 01:11 AM
BRZ+ Long legs + heel-toe downshift = fail ? Breeeep Tracking / Autocross / HPDE / Drifting 10 10-15-2014 03:25 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 03:41 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 12:01 PM
