Old 04-28-2020, 11:13 AM   #1
AJ124
Drives: 13' Toyota GT86
Cusco Rear LCA
Hoping someone here can help, I have tried searching but failed to find anything.
I have some Cusco rear LCA's installed and after a few years the pillow ball's have worn enough that there's some play.
Does anyone know the correct size of pillow ball's for the Cusco arms?
AJ124 is offline   Reply With Quote
Old 04-28-2020, 11:26 AM   #2
p1l0t
p1l0t's Avatar
Old 04-28-2020, 01:44 PM   #3
strat61caster
strat61caster's Avatar
I'd contact the UK Cusco dealer, coordsport first, then Cusco USA second, or maybe CSG can get you specs/replacements.
https://www.cusco.co.jp/en/distributor/
ineedyourdiddly
Old 04-28-2020, 02:35 PM   #4
Racecomp Engineering
I would contact Cusco UK.
But you can also measure what you have. Detailed dimensions are all available on the rod end sites so you can compare fairly easily. Or see if a place like www.mcgillmotorsport.com can help you (no personal experience, there are plenty of other options in the UK).
I have a set off the car, but they're in storage and not at my house. When the time comes I'll measure and replace them on my own.
EDIT: sorry, one note is that the rubber boots will be absolute misery to get off without a special tool. that would make things a little more complicated.
- Andrew
Old 04-28-2020, 03:57 PM   #5
AJ124
Thanks @Strat61 and racecomp. I have emailed Cusco, but not heard backs thought I'd ask here incase anyone has had to change them already.
As racecomp mentioned the rubber boot will make it a pain to measure without stripping off the car.
Will see if coordsport can help.
Old 04-30-2020, 05:46 AM   #6
AJ124
Got a reply from Cusco JP, they use HRT18E NMB end's for anyone else that might need some.
http://bearingsize.info/catalogue-on...obj143330.html
FS: Cusco Subframe Collars, Cusco Rear Differential Collars (Front and Rear). FRSH86 Transmission and Driveline 0 04-19-2020 12:36 AM
<FS> Perrin 25mm rear sway, Radium front strut, Cusco rear strut bar mav1178 Brakes, Suspension, Chassis 2 07-21-2016 05:49 PM
FS: Cusco Power Brace Front, Rear, Rear-side Member and Engine Room fungus Canada Classifieds 2 05-20-2016 11:36 AM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
