Old 04-28-2020, 10:31 AM   #1
kazerotor
Drives: 2014 Scion FR-S
Drive Side Door Not Locking
Hey guys, I've done a search and found some information around the issue but nothing concrete. I'm having a problem with my door lock, but I was curious if someone has experienced this issue, and what part was it that failed?
It's a 2014, The driver side does not lock from the inside when using the switch. When setting the alarm with the keyless entry, and locking the doors, the driver side does not lock.
Recently someone got into my car and took some stuff, then found out my door hasn't been locking this whole time. I have to do it manually before getting out, and using the key to open the car.
Thank you if anyone can point me in the right direction!
kazerotor is offline   Reply With Quote
Old 04-28-2020, 10:46 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Try getting a replacement switch. They are common and cheap, just get the section that has the lock buttons and window switches
The Following User Says Thank You to DarkPira7e For This Useful Post:
p1l0t (04-28-2020)
Old 04-28-2020, 10:55 AM   #3
p1l0t
p1l0t's Avatar
Yeah if it is mechanically working I would also assume it was the switch.
Old 04-28-2020, 12:11 PM   #4
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
In addition to the switch, there has to be a solenoid or motor actuator between the switch and the mechanical locking mechanism. Not sure if this is a separate part or just what.
LimitedSlip is offline   Reply With Quote
Old 04-28-2020, 01:51 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'd blame the motor before the switch. I remember that another person with the same issue discovered grease had contaminated the commutators on the motor.
From the link in my sig:
Components
Removal
Inspection
soundman98 (04-28-2020)
Old 04-28-2020, 05:54 PM   #6
kazerotor
Awesome, thank you guys. I'm gonna take a look into this further and see what I can rule out. I know for sure the does lock and unlock by the key.
When I lock the car through the keyless, I hear the passanger side lock. and If i'm not mistaken. I hear the driver side try to do something quickly but just doesn't.
Old 04-28-2020, 09:16 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
switches tend to affect all locks, not just one side. my bet is on something with the actuator
Old 04-29-2020, 07:43 PM   #8
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
The rod from the actuator may have become disconnected from the lock mechanism. Without resistance, the actuator moves "quickly". Different rods connect the manual lever and the key-actuated mechanism to the lock.
tarzan_nojane is offline   Reply With Quote
The Following User Says Thank You to tarzan_nojane For This Useful Post:
soundman98 (04-29-2020)
Old 04-30-2020, 01:37 AM   #9
Kaotic Lazagna
Drives: GR Corolla
I had this problem with my Yaris. I took apart the actuator and replaced the little motor (I could have cleaned the factory one, but I felt better just replacing it). Works fine now.
Old 04-30-2020, 01:41 AM   #10
Kaotic Lazagna
Drives: GR Corolla
That's for the Yaris, but I'd imagine the twins' would be fairly similar.
Old 04-30-2020, 12:03 PM   #11
kazerotor
Thank you! There's actually a couple folks who have posted videos on disassembling the door panel on youtube!
I'm going to replace the actuator though, because it seems to have a dirty contact problem as mentioned earlier in the thread and see if it works.
Old 04-30-2020, 03:07 PM   #12
Kaotic Lazagna
Drives: GR Corolla
If you can find out the size of the motor, you can probably save quite a bit of money by just replacing it, versus replacing the whole actuator assembly.
WTB BRZ Driver's Side Door, WRB ngabdala Cars for Sale/Trade 1 06-17-2015 10:18 PM
WTB BRZ Driver's Side Door, WRB ngabdala NY / NJ / CT / PA 0 06-16-2015 06:17 PM
WTB BRZ Driver's Side Door, WRB ngabdala New England 0 06-16-2015 06:16 PM
So I messed up my side door... BRZprime Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 10-05-2013 10:53 PM
Locking the door.... huma BRZ First-Gen (2012+) — General Topics 15 08-19-2012 04:56 PM
