Old 04-22-2020, 06:48 PM   #1
lareigno
lareigno's Avatar
Drives: 2016 Scion FRS
trouble reading with oft
Hey guys. I bought a new oft v2 for my used 2016 FRS. Everything is fine running up to the point after I click read. It gives me an oftcode 10003 which has lead me to believe that the ecu is locked by a previous tune. I tried taking the car to the toyota dealership and they said the ecu hasn't been touched by the previous owner and that they were able to access the ecu fine. I'm able to receive the real time diagnostics and ECU info. I tried the process multiple times checking for secure connections but I keep getting the same results. Any help or suggestions would be great!
lareigno is offline   Reply With Quote
Old 04-22-2020, 11:36 PM   #2
steve99
ok it does sound like its been tuned with brzedit or ecutek and ecu is locked.
The toyota guys likely just did diagnostics and didnt try to write the ecu. there tool only writes it has no read.
If oft doagnostics works that confirms oft is talking to ecu
if its ecutek it might be multi map tune.
with engine running and cruise control switched OFF, pull the cruise stalk towards you and hold for a few seconds. see if the tachometer jumps to 1000,2000,3000,4000 if it does its ecutek tune.
if it doesnt its eitger single map ecutek or brzedit
Old 04-23-2020, 11:22 PM   #3
lareigno
lareigno's Avatar
When I held the stalk the tachometer just jumped to 1000 and stayed there. I'm just worried because I do not have contact with the previous owner so i'm not too sure how to get back to stock if it's either ecutek or brzedit.
Also, thanks for replying so fast lol
Old 04-24-2020, 02:34 AM   #4
steve99
Ok if tacometer jumped to 1000, then its definitly ecutek tune. which is good news as ecutek is much more popular than brzedit and the ecutek licience in ecu is worth $300 USA
Old 04-24-2020, 02:36 AM   #5
steve99
Your best option may be to see if you could return oft or sell it.
Then either get an ecutek tune or buy an ecutek cable
Old 04-25-2020, 04:34 AM   #6
Contender
Drives: 2017 Toyota 86
Don't put it back to stock that's crazy
Contender is offline   Reply With Quote
Old 04-25-2020, 04:39 AM   #7
lareigno
lareigno's Avatar
haha don't worry it's not going to be stock. I just wanted to know if it was a just a locked stock ecu by ecutek for future tunes.
CEL trouble steelheart100 Issues | Warranty | Recalls / TSB 9 04-18-2018 04:24 PM
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 06:44 PM
OFT not reading 904FRSlow Software Tuning 34 11-04-2014 06:40 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
