Old 04-21-2020, 12:18 PM   #1
sexyslidez33
Drives: 2013 Scion FRS, 2003 Nissan 350Z
Splash 540S steering hub problem?
I just installed a splash 540S steering wheel hub and I am a bit confused. I tried feeding the clock spring wiring through the hole and I can’t put the hub through the spline. I saw the NRG short hub requires you to tuck the wiring behind the hub.
I did this with the splash hub and everything seems fine, I am not sure if it will mess up the clock spring in the long run though.
This should be ok right? I also am getting an indent with the harness plug through the black cover.
I have the same hub with my 350z and everything went super smooth, I had trouble with the FRS though.
sexyslidez33 is offline   Reply With Quote
SOLD socal splash steering wheel hub toby714 Interior Parts (Incl. Lighting) 9 06-16-2016 11:39 PM
Works Bell/Splash Steering Wheel Adapter derek1ee Want-To-Buy Requests 1 03-30-2016 11:59 PM
FS: Steering wheel Splash hub/Worksbell hub BRZ NA Interior Parts (Incl. Lighting) 28 02-19-2015 09:00 AM
Splash Steering Wheel Hub Adapters at RallySport Direct! RallySport Direct Interior Parts (Incl. Lighting) 4 10-31-2014 11:29 AM
Works Bell Splash Boss Steering Hub Kit dizzario Interior Parts (Incl. Lighting) 7 08-06-2014 04:29 PM
