Old 04-18-2020, 02:34 AM   #1
brzcui
Drives: 2014 supercharged brz
pads and rotors/spring recommendations?
I had my car for like over an year now and the pads and rotors are on its way out, it is to the point that i have to brake ahead of time so they would work. Yesterday i was hitting downhill on this mountain roads and i was braking kinda hard from like 90mph and im pretty sure i fried them and i heard them screaming for like 5 mins after on the way home. What is the best pads and rotors you guys would recommend? i don't track my car but i need something that would withstand the heat and abuse, whats the best pad, rotor stainless lines and brake fluids set up for my driving? also any recommendations on custom spring rate setup for track? im running tein mono sports but i think a harder spring would help me corner better. Thanks in advance.
brzcui is offline   Reply With Quote
Old 04-18-2020, 04:25 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
"i don't track my car" but "recommendations on custom spring rate setup for track"? :/
I have no clue from your post if you want brakes and suspension setup for DD or track. Optimal choices are exclusive for use with cons overcoming pros when used differently and hybrid solutions having their deficiencies/limits at either vs specialized solutions.
Old 04-18-2020, 04:45 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Chances are you just need new pads.
Rotors: if you actually need them, there are zero advantage from slotted/drill ones. Just the sucker higher price tag.
Any oem-ish ones would do a great job.
Pads: depends on your wallet you can chose a crap ton of them. If you do 95% of daily driving anything a notch above oem would do just fine. TRD's pads are some, but for the price point there are lots of others to choose from. Some one else can put their recommendations.
S.S. lines: biggest scam ever. It's literally just a new hose with a fancy jacket. Save some money and just buy a S.S. dress up sleeve.
Brake fluid: unless you are hitting the track every weekend, any brake fluid would do fine.
But if you want spend a few bucks more, you can go with any "race" or "high performance" brake fluid.
Springs: If you don't track your car, you don't need it. If you don't plan to track your car you won't need it.
But.... if you want a better springs I would lose the Tein. As to which? That depends what you want from them.
Like I said if you don't go to the track or plan to, a notch above oem would do fine. Either STI or TRD springs would be fine.
The Following User Says Thank You to Mr.ac For This Useful Post:
strat61caster (04-18-2020)
Old 04-18-2020, 11:23 AM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
while i agree on drilled rotors, i disagree on slotted rotors. they do offer a benefit of wiping the pads, which has been noted to make initial bite much more consistent. but it comes at the cost of additional dusting and lower pad life.
from a reliability standpoint, stainless steel lines are marginally better, as the stainless steel is containing some of the line pressure. again, this is a mod specifically done for more consistent brake feel.
Old 04-22-2020, 08:10 AM   #5
i8ur911
Drives: 17 BRZ Series.Yellow
Here's some real world advice for a daily driven street car....
If you have zero intention of tracking the car, install OE or OEM brake parts. The reason your pads are fading right now is likely because your pads are low and they're not able to dissipate the heat properly. More pad and the thicker the rotor, the more thermal capacity your brakes have.
Also, if you're brake fluid is more than a year or 2 old, it likely has absorbed some moisture which again leads to poor braking.
I'm regards to suspension, if you're looking to get rid of some body roll but keeping similar ride comfort, I'd recommend sway bars. The factory bars are very thin in diameter and a nice set of thicker bars will help get rid of that unwanted body roll.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
The Following User Says Thank You to i8ur911 For This Useful Post:
strat61caster (04-23-2020)
Old 04-23-2020, 01:23 PM   #6
strat61caster
strat61caster's Avatar
TRD pads were cheaper than the OE last I looked, worth checking out if OP wants something a touch 'sportier'
ineedyourdiddly
Recommendations on where to check/resurface rotors? stockysnail Northwest 4 05-18-2017 02:57 PM
DBA Rotors and CarboTech Pads AndyBRZ Brakes, Suspension, Chassis 3 07-14-2016 08:22 AM
Track-Only HPDE Brake Pad recommendations. Stock platform/calipers/rotors fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-20-2014 12:03 PM
GTS OEM rotors and pads yomchi1989 AUSTRALIA 1 12-30-2012 04:47 PM
GTS OEM rotors and pads yomchi1989 Australia Classifieds 0 12-28-2012 06:28 PM
