Old 04-15-2020, 11:53 PM   #1
RippedManiac
Jedi
Drives: Pikachu BRZ
OFT Tuning Alerts Question
Hi Everyone,
I recently went OFT stage 1.
I set a tuning alert for IAM less than 0.6 for I usually run 91.
Every time I enter the Realtime data mode, it beeps twice.
Im running V4 tune. Its supposed to start at .7 but the number usually climbs up to .8 - .9 which is good, but the first 2 beeps worry me.
I know its supposed to do a constant beeping sound if an alert is triggered.
Ive also seen my FLKC hit .7 and -1.4 but 0 KC learned. Not exactly sure what these mean.
Is this normal?
Pls and Thank you!
RippedManiac is offline   Reply With Quote
Old 04-17-2020, 03:49 PM   #2
dholloway543
Software Hobbiest
Drives: 2015 FRS
Mine beeps 2 times whenever i open the data monitor. I think its just the notification that the alert is turned on.
Then the screen flashes black every update until the perimeters set are exceeded then it flashes white every update. Probably to help grab your attention when your car is screaming and making lots of noise.
dholloway543 is offline   Reply With Quote
The Following User Says Thank You to dholloway543 For This Useful Post:
RippedManiac (04-21-2020)
Old 04-17-2020, 03:58 PM   #3
tomm.brz
Drives: brz 2017 hksv2
KC learned is just a projection of a table called Knock correction A in Romraider.. don't care about it
those corrections are not so bad, you can maybe fix them by lowering 0,35 of ignition timing in that zone in the base timing B table
The Following User Says Thank You to tomm.brz For This Useful Post:
OFT tuning alerts sandy s Software Tuning 0 12-07-2018 08:30 PM
Question about custom tuning and tuning DGM-BRZ Software Tuning 6 08-01-2016 11:37 AM
OpenFlash Tablet Update (Template and Tuning Alerts) Shiv@Openflash Software Tuning 60 04-13-2016 05:59 PM
email alerts in car echo419 Issues | Warranty | Recalls / TSB 3 12-19-2014 02:16 PM
FI tuning question Fear Forced Induction 33 05-30-2014 09:40 PM
