Old 04-11-2020, 04:41 PM   #1
fardaus
Drives: Stock car
Coilovers for winter + daily drive
I'm looking for coilovers that will work fine in winter and comfortable for daily drive. I've heard about KW basically being corrosion and rust proof, not sure if they're suitable for daily driving or which variant is better. I don't have a set budget as I rather save up, so I'm open to other brands as well. Thanks
fardaus is offline   Reply With Quote
Old 04-11-2020, 05:00 PM   #2
i8ur911
Drives: 17 BRZ Series.Yellow
Any coilover is likely to experience some corrosion and seizing if driven on in extreme winters......salt, snow, ice, etc.
If you experience the above mentioned weather, I'd recommend getting coilover covers and using those, at a minimum, in the winter.
If you're interested, I have a set of KW V1's for sale.
Sent from my Pixel 3 using Tapatalk
i8ur911 is offline   Reply With Quote
Old 04-11-2020, 05:30 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
My line of thought goes like this.
In winter no need for stiff spring rates to counter any roll on sticky tires, due grip levels being very very low. And roads might be worse, so softer rates will net extra road compliance/comfort.
Extra ground clearance also will be helpful to not get stuck in deep snow.
And your mentioned construction points to stand well against salt and dirt. Though might be replaced by lower cost, so that it's cheaper to replace.
Summarizing it all, i'd think of something like bilstein B6 struts with stock springs. Stock height, relatively cheap, not over-stiffened.
Old 04-11-2020, 05:36 PM   #4
StraightOuttaCanadaEh
Wes
Get ISC coilover socks. Put them on at the same time I installed my coilovers. The car just went through its 4th winter
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
i8ur911 (04-11-2020), SuperTom (07-07-2025)
Old 04-11-2020, 09:26 PM   #5
strat61caster
strat61caster's Avatar
Kw spring rates are pretty soft and their spring perches are plastic so slightly more corrosion proof than most coilovers with metal perches. They also use oe top hats which will further help with DD/longevity.
ineedyourdiddly
DarkSunrise (04-11-2020)
Old 04-11-2020, 10:56 PM   #6
DarkSunrise
DarkSunrise's Avatar
KW V1 and V3 also have lifetime warranties for the original purchaser, so if they were to fail, you would have a potential remedy.
2022 BRZ Build
2013 FR-S Build
Old 04-12-2020, 12:47 AM   #7
fardaus
Drives: Stock car
Cool nice to know. Do you know if V1 is better for DD than V3?
Old 04-12-2020, 01:27 AM   #8
strat61caster
No idea, but since you just want to drive around town odds are you'll never want to play with damper settings so save your money and get the v1s.
ineedyourdiddly
Old 04-12-2020, 09:33 AM   #9
i8ur911
I would say it depends on your use.
The V1 is height adjustable, but not damping adjustable.
The V3 is height adjustable, but also damping adjustable......both rebound and compression.
Some might argue that the V1's are good for the street and the V3's should be used on the track, but ultimately it depends on the owner.
Old 04-12-2020, 01:42 PM   #10
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Personally, if daily livability is your primary concern (and rust prevention is a factor) then I'd look no further than the Bilstein B14 or B16.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following 2 Users Say Thank You to Goingnowherefast For This Useful Post:
Pat (04-12-2020), strat61caster (04-12-2020)
Old 04-14-2020, 12:11 PM   #11
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I see winter too. I am likely going with RCE yellows and B6, when the stockers give out.
Ernest72 is offline   Reply With Quote
coilovers, daily driven, winter
86/BRZ for winter daily driver? FRSJ CANADA 20 10-15-2017 12:20 PM
Winter + Daily Driver Oil Selection Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 12-09-2016 12:23 AM
Do you have daily drive car? oso_25 Other Vehicles & General Automotive Discussions 51 05-11-2015 04:52 PM
If this car is your daily driver, how is it doing this WINTER? With the potholes..... rogerdalien Scion FR-S / Toyota 86 GT86 General Forum 52 02-27-2014 03:28 PM
Longest daily drive? cuddefred Scion FR-S / Toyota 86 GT86 General Forum 6 05-22-2013 01:00 AM
