Old 08-07-2012, 11:32 AM   #1
PRORICAN
PRORICAN's Avatar
Another engine swap topic!
I'm new to Subaru and boxer engines and recently found out the 3.6R motor from the outback is also a boxer. Has anyone modded that engine and how is the aftermarket for it? It seems like a good potential swap for us if it's worth it...
PRORICAN is offline   Reply With Quote
Old 08-07-2012, 12:10 PM   #2
ahausheer
Re-member
Drives: Toyota camry
FYI: All Subaru motors are boxers. That engine probably would simply not fit in the engine compartment and if it could it would add a lot of weight. Some Subaru's respond very well to aftermarket parts/tuning but I dont know about that Outback motor.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 08-07-2012, 12:57 PM   #3
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
Well, we already know that the EJ series engines aren't a direct bolt-in and the EZ36R has the same bellhousing bolt pattern as the EJ. The FA in the BRZ/FR-S is a physically smaller motor than the EJ, too. I'd love to have a 6cyl BRZ but I just don't think that's going to happen without major modifications.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 08-07-2012, 01:09 PM   #4
Tainen
Drives: First SWP BRZ-L
yep, as Jimbo said, the tranny's don't fit. All the other Subaru transmissions are AWD units with different designs.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 08-07-2012, 01:25 PM   #5
bullitt@uamotorsports
Drives: 1500hp 450zTT
I personally would like to see an LFA motor swap... just wish I won the lottery then I would do it haha!
bullitt@uamotorsports is offline   Reply With Quote
Old 08-07-2012, 02:12 PM   #6
empower-auto
Kouki-Monster
empower-auto's Avatar
I personally would like to see people quit trying to swap this motor out - and try making the best of it.
It's a good engine from what we've seen and it responds very well to bolt-ons. I am sure there is a ton of potential here.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following 3 Users Say Thank You to empower-auto For This Useful Post:
Crawford (08-08-2012), dabocx (08-07-2012), eriktherod (08-07-2012)
Old 08-07-2012, 02:14 PM   #7
thermobox
Drives: 16 Impreza 5dr CWP
Fisked.
Originally Posted by ahausheer View Post
FYI: All Current USDM Subaru motors are boxers. That engine probably would simply not fit in the engine compartment and if it could it would add a lot of weight. Some Subaru's respond very well to aftermarket parts/tuning but I dont know about that Outback motor.
All the kei cars were inline engines. The other Subyota - Dex, Sambar, Justy, R1, R2 all used inline engines.
thermobox is offline   Reply With Quote
Old 08-07-2012, 02:24 PM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
my dream engine swap is EE20 engine, i can smell it now.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-07-2012, 08:02 PM   #9
PRORICAN
PRORICAN's Avatar
Don't get me wrong I have no intentions of swapping the motor but I grew up in the Honda scene so swapping motors was very common. A 6cyl BRZ would be very cool and the boxer 3.6r would keep the center of gravity low in theory. I have high hopes for the FA20 and plan on keeping it but it doesn't hurt to explore other options. Coming from an Evo X I'm missing the power and torque, lol. And yes I knew this car would lack the power and don't regret my decision.
Old 08-07-2012, 09:51 PM   #10
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
the EZ30R is a bit stronger due to the conventional rod design, you'd use an EJ 5 or 6 speed box with RWD spool installed. EZ's have been converted into old foresters and impreza's so there's no reason someone couldn't give it a shot in an 86. They go quite nicely when turbocharged.
Custom exhaust, custom radiator, custom tailshaft, custom shift linkages, custom loom etc. Anyone who has experience with real conversions shouldn't have much trouble with it.
JP is offline   Reply With Quote
Old 08-07-2012, 09:55 PM   #11
dabocx
dabocx's Avatar
Drives: Scion FRS
I think by the time your done swaping your stock used 6cylmotor into the car it will end up cost more than just boosting the FA20
dabocx is offline   Reply With Quote
Old 08-07-2012, 10:02 PM   #12
PRORICAN
PRORICAN's Avatar
True but you still have more displacement and the potential for more power with a much broader power band. It doesn't matter anyways, chances are it won't happen. I just wanted to see what peoples experience and opinions with that motor were since I have zero.
Old 08-07-2012, 10:34 PM   #13
xwd
People have swapped the 3.6R into various Subaru vehicles already although not many. Outfront Motorsports (used to be Outback) who build sand rails with Subaru engines turbo'd a 3.6R and found the crank to be the weak part of the engine. At around 10PSI of boost the cranks had a tendency to fail. The 3.0R is more sorted, plenty of folks have built turbo Imprezas with them, including Perrin. The wiring is always the nightmare.
Have you seen the powerband on the new FA20 DIT motor Subaru just came out with? Or the Accelerated turbo kit thread? Definitely a better and likely cheaper option, even if you had to build the bottom end of the FA20 to handle more boost.
Old 08-07-2012, 10:43 PM   #14
PRORICAN
PRORICAN's Avatar
Well I guess that's a nightmare I'll avoid. I'll be definitely going turbo but I'll wait and see what more R&D gives us.
Engine Swap: Which Would You Choose!?? EvoFanatic Engine Swaps 149 08-08-2017 03:34 AM
Has any FRS/BRZ fallen to LS V8 engine swap? suzuka Engine Swaps 216 09-15-2016 03:15 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 01:08 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
