Old 04-05-2020, 06:55 PM   #1
Brooklyn
Brooklyn's Avatar
Drives: 2014 DGM BRZ
Brake pad shim broken/rusted through
Hi all, so my '14 BRZ (127xxxkm, 79xxx mi) lately has been making intermittent squeaking noises while braking, and also when I'm not braking. When I do brake i can hear some sort of grinding, seemingly more toward the rear wheels. I'm thinking, I don't go hard on the brakes, don't drive the car hard often, no rally cross or anything - so how could my brake pads be done?
So I decide to check on the rear brake pads and what do I see...
- so much rust in general
- rust between the metal shim/backplate of the brake pad with the imprint of caliper piston/cylinder
- when i go to try and adjust the shim/backplate, its rusted through and then actually fell apart after
So now, i put the caliper back together with my wheel, without the shim/backplate between the caliper cylinder and the brake pad.
Questions:
- anybody encounter this before?
- I assume it'd be safer not to drive the car for now, any idea if you can buy the shim or do I need new brakepads?
- also, wtf?
Thanks
Pics:
https://imgur.com/oyVACYf
https://imgur.com/vCYI743
https://imgur.com/klSy3Bo
https://imgur.com/KEPEMsk
Brooklyn is offline   Reply With Quote
Old 04-05-2020, 07:36 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The shim just helps reduces noise. They are not actually needed, I don't run them on my car.
Old 04-05-2020, 11:12 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Not absolutely required. They're a vibration damper to help with squealing. Some lube on the same spot can help with this too.
A drill with a wire brush would do a good job cleaning some of that rust up.
The rotors look like they have seen better days. Rockauto has some good cheap stuff like centric blanks. Around $46 per.
Brake Rotors: Rusted Stuck Apex_BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-21-2019 03:40 PM
Custom Valving Coilovers: How to gauge shim stack and shock force graphs FeRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 08-16-2019 05:46 PM
TRD brake pads installed... rusted caliper question select20 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-03-2016 11:19 PM
Does anyone have a complete valve shim kit that I can rent or borrow? D K Engine, Exhaust, Transmission 0 04-13-2015 02:42 PM
Valve shim confusion.. Hempo Engine, Exhaust, Transmission 0 02-16-2015 04:45 AM
