Drives: 2013 BRZ Limited
Difference between AeroCatch hood pin models?
I’ve tried searching online without any luck.
Does anyone know the difference between AeroCatch 1 vs AeroCatch 1 Xtreme vs AeroCatch 2? Any pro’s/cons about the above panel vs below panel design?
ProCrastinationConsultant
it says it all on their site.
1 has a aluminum strike pin 1 extreme has a steel strike pin 2 has an extended sheer pin that goes into a prepared frame for additional security. their site also says the above/below designs are exactly the same, the below just offers improved aesthetics for those that so desire.
| The Following User Says Thank You to soundman98 For This Useful Post: | Suparu (04-04-2020) |
Thanks!
I’ve had Q-clip hood pins w/ lanyards in the past and the strike pin began to rust after a couple years. I read that aluminum is more corrosion-resistant than steel so it seems for that reason, the Xtreme would be less preferable.
| FS: Seibon Carbon TS hood, Sparco hood pins, Clear coated $650 (Lawndale) | iceblaze | Southern California | 1 | 04-14-2019 03:50 PM |
| Am I crazy seeing difference in color for my hood? | lowfive99 | BRZ First-Gen (2012+) — General Topics | 8 | 06-13-2015 08:30 PM |
| Aerocatch hood pins, anyone got pics and comments? | K-NoMs | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-28-2014 12:51 PM |
