Drives: Satin Black Scion Frs
Car Fails to start! Parking sensor??
Car:
- 2013 Scion FRS (Automatic) Battery: - Replaced less than a year ago Codes: - P0700 - P0851 Replacements attempted: - Switched out Park/Neutral Sensor My vehicle is having trouble starting. When turning the vehicle, it will not do anything, lights dim (as normal) but the car will not crank at all. The first time this happened, I cleaned the positive and negative terminals with a tool and then the car started. But as soon as I turned it off, the boom will start to turn over. In addition, when switching the car on (or switching to any gears), the car will jolt forward hard. This made me think of the park/neutral sensor located on the transmission. I ordered the part and had it installed this morning but the car still does it. This morning was the first time I had a portable battery on since it was a dead after 1-2 weeks of non-starting. It starts after 2 attempts but the whole jolting thing is horrible. I'm going to send my car to a buddy's place to diagnose it more with the proper equipment. Can someone give me suggestions on what to tell him to look at specifically and check? What could this be? Starter? Battery? ETC. Every time I clear the code, it comes back when the car starts. |
#2 | |
Sent from my GM1915 using Tapatalk |
#3 | |
Thank you for the reply, but unfortunately, this vehicle is an automatic.
But that did give me some more info on the set up of starting. |
#5 | |
![]() Sent from my GM1915 using Tapatalk |
I'll attach this to my buddy when I sent the car off tomorrow as well to look at.
#8 | |
I kinda want to take it off. Since I know where the pin is at now, after so many times. I can reach it from sitting in the driver's seat so it's like a free kill switch ![]() Sent from my GM1915 using Tapatalk |
#9 | |
his car is an auto - have another cup of coffee - ![]() humfrz |
#10 |
That's true but that picture only shows two pedals. So u really think it's gonna be that switch. When u sit in your car and turn the key with out hitting the brake the car doesn't crank it just turns on electronics. But when u press the brake then it cranks. So my guess is that switch is behind the brake pedal as it is behind the clutch in a manual. Honestly save the tow, and check then you'll save your buddy some time trying to figure it out.
#11 | |
![]() humfrz |
#12 |
If the starter motor cranks engine its not the park\neutral switch. If its faulty it wont crank.
If car is cranking and engine fires up then its not a start circuit problem its something else. Last edited by steve99; 03-23-2020 at 08:19 PM. |
#13 |
I think it's just loose somehow idk, cuz I turn on my car by simply pressing that button without having to have the clutch engaged
#14 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Guys, really, holy shit, stop saying nonsense.
P0700 is a generic transmission fault code, think of it as being the transmission's way of turning on the check engine light. P0851 is a PNP CIRCUIT LOW fault. The transmission jerks hard in when put in gear because it's in fail-safe mode, as it feels it's TRS/PNP switch is unreliable. The car doesn't have a clutch switch! JFC! OP, unfortunately, throwing parts at something is a shitty way to do things. Go here, navigate to your year's repair manual, then Engine/Hybrid System -> FA20 Engine Control -> SFI System -> P0851 Park / Neutral Switch Input Circuit Low. Step by step on how to find what's wrong, but the gist of it is, check for battery voltage across terminal 4 and 5 of the pnp connector with key on. Test light go bling = the problem is the pnp switch, or thereabouts. KEEP IN MIND! you threw a switch at it, is it correctly aligned? What caused the original no-crank condition? ASK YOURSELF! has the shift lever ever been hard to move at all? it is frequent for cars of a certain age to have shifter cables and linkages that start to bind. A linkage may bind at both ends of it's travel range, at one end of that range is the Park contact inside the switch, giving the shift lever a good slap is usually a good test of this, or just moving the lever to neutral to see if it starts there! It's called a park/neutral switch because the car can be started in either park or neutral! |
| FRS/BRZ Parking Fails | go_a_way1 | Off-Topic Lounge [WARNING: NO POLITICS] | 21 | 04-04-2016 02:51 PM |
| Rear parking sensor | Eighty 6 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2016 11:05 PM |
| Subaru BRZ with Proximity Key Fails to Start | eprosenx | Issues | Warranty | Recalls / TSB | 36 | 02-10-2016 11:15 PM |
| Gearflag PRK902 8 sensor parking system | DIREWOLF | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-21-2014 12:49 AM |
| Car fails to start. | ericvanderwoodsen | Issues | Warranty | Recalls / TSB | 8 | 03-14-2013 12:36 AM |
