Old 03-21-2020, 07:24 PM   #1
powerwdp
Drives: 2018 Toyota 86
OFT Unstable revs when shifted to R/D from Parking
Hi I got a 2018 toyota 86 auto recently added JDL catted UEL and OFT tune (Stg-2-v4.03-ZA1JN10D.bin). But after that I found every time after cold start, if I don't let the car fully warmed up, the rev will rise to 2000+ immediately after switching to R/D and then be quite unstable when I releasing the brake.
It make some trouble when I want to move preciously in the garage, just want to know is there any solution for that? I attached a video and the tune file I've used. You can see from the video that I never touch the throttle but the rev is keeping bouncing...
[ame]https://www.youtube.com/watch?v=IlqecsbqOEw[/ame]
powerwdp is offline   Reply With Quote
Old 03-21-2020, 08:32 PM   #2
kev0
Drives: '14
How many miles since the tune? If less than 200, check back in after you reach those 200 miles so the fuel trims are fully learned. Post a log if you can. A vacuum leak in the header can cause that.
kev0 is offline   Reply With Quote
Old 03-22-2020, 06:48 AM   #3
steve99
Maf correction after start values are incorrect in both in nrutral and in gear tables.
Ive fixed this for a few people
Old 03-22-2020, 10:47 AM   #4
powerwdp
it is pretty new with new gaskets, should be under 50 miles, I'll check back later.
Old 03-22-2020, 10:48 AM   #5
powerwdp
I did some research and found below part may be the one you mentioned.
Code:
		<table name="MAF Correction After Start (Neutral)" storageaddress="11C868">
		  <table type="X Axis" storageaddress="11C81C" />
		  <table type="Y Axis" storageaddress="11C848" />
		</table>
		<table name="MAF Correction After Start (In Gear)" storageaddress="11C964">
			<table type="X Axis" storageaddress="11C918" />
			<table type="Y Axis" storageaddress="11C944" />
		</table>
Can I rewrite the address using the stock value to fix that? Not sure if that will works properly with aftermarket parts...
Thanks!
Old 03-23-2020, 01:53 AM   #6
steve99
Code:
        </table>
        </table>
Thanks!
The def is correct just the values in table are in correct . You just need to change the valies in the tables in romraider.
Use the values in the maf after start tavles at bottom of the picture below ie the tavles with max value 20, copy in the whole table to your tune, make both in gear and in neutral same
Old 03-23-2020, 04:26 PM   #7
powerwdp
Thanks for the information!
I've downloaded romraider and check my value, it looks a little bit different. The value is higher for idle mode 7/8 and has a low-high-low trend for in gear table.
should I make the in gear table exactly same as neutral table or keep its trend but lower the number?
Old 03-23-2020, 06:18 PM   #8
steve99
Just make fhe in gear an neutral tables same, that way when you shift from neutral to a gear the rpm wont change
From memory ghe original tavles had higher values at bottom rows which made rpm rise more as car warmed up
Old 03-23-2020, 10:20 PM   #9
powerwdp
Just want to confirm that I haven't done something wrong...
Old 03-24-2020, 03:42 AM   #10
steve99
Swap rows 1,2 with 7,8 in both tables
Tats whats causing issue
Old 03-24-2020, 02:22 PM   #11
powerwdp
That solved the problem, I really appreciate it!
Can you describe a little about difference between row 1/2 with 7/8? Not sure why they switch those row for later map.
Old 03-25-2020, 01:39 AM   #12
steve99
The ecu runs through thte rows in order from 1-8 , over the warm up period
I think they just made a mistake when the made the tune
Old 03-27-2020, 09:27 AM   #13
powerwdp
The starting idle rev is a little bit low, I just rise it to 20/16/16/15/12/9/x. Hope that will work properly.
Old 03-27-2020, 10:31 AM   #14
tomm.brz
Drives: brz 2017 hksv2
in those tables, the first 2 rows do not set the idle rpm, mostly just the initial throttle blip behaviour
rows 3-8 best to keep them stock for warm/hot start stability
Unstable revs when switched to R/D from P powerwdp Engine, Exhaust, Transmission 3 03-22-2020 10:53 AM
Money Shifted my car, should I be nervous? norcalpb Engine, Exhaust, Transmission 11 12-31-2019 06:38 AM
Unstable idle when A/C cuts out paulca Engine, Exhaust, Transmission 14 10-24-2015 09:18 PM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
Unstable feeling Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2013 11:06 AM
