Old 03-21-2020, 05:03 PM   #1
powerwdp
Drives: 2018 Toyota 86
Unstable revs when switched to R/D from P
Hi I got a 2018 toyota 86 auto recently added JDL catted UEL and OFT tune (Stg-2-v4.03-ZA1JN10D.bin). But after that I found every time after cold start, if I don't let the car fully warmed up, the rev will rise to 2000+ immediately after shifting to R/D and then be quite unstable when I releasing the brake.
It make some trouble when I want to move preciously in the garage, just want to know is there any solution for that? I attached a video and the tune file I've used. You can see from the video that I never touch the throttle but the rev is keeping dancing...
[ame]https://www.youtube.com/watch?v=IlqecsbqOEw[/ame]
powerwdp is offline   Reply With Quote
Old 03-21-2020, 07:41 PM   #2
Lantanafrs2
Drives: 2013 frs red
How many miles since tune was installed?
Old 03-22-2020, 10:44 AM   #3
powerwdp
Only <50 miles.
Old 03-22-2020, 10:53 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
Yup, with OFT tunes mine did it both OTS and custom. need to let it warm up and idle longer.
If you put it into R or D before the idle revs have dropped below 1k it will do that and drive a bit odd. I just let it idle another 30seconds or so and no issues.
New Rear Tires & Alignment now unstable EzyBreezy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-28-2019 12:53 AM
Unstable idle when A/C cuts out paulca Engine, Exhaust, Transmission 14 10-24-2015 09:18 PM
New front sway, a little unstable on left turns loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-20-2015 07:38 PM
2.5L with lower revs/more torque, or 2.0L with higher revs? Superhatch Engine, Exhaust, Transmission 124 08-28-2013 12:20 PM
Unstable feeling Toyobaru808 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-28-2013 11:06 AM
