Old 03-20-2020, 04:24 PM   #1
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
TRD Spoiler bolts on a BRZ?
I've research for months, finally got a heavily USED TRD Lip.
Do people cut off the bolts? I want to keep them and put vinyl/tape over the trunk portion that will be hit by the bolts.
Any tips or suggestions? I'm using some thin 3M VHB tape. Should I take off the OEM weather stripper or put 3M on top of the weather strippering?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks!
I know I gotta de-badge too.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
The Following User Says Thank You to SmartedPanda For This Useful Post:
meWant (03-20-2020)
Old 03-20-2020, 06:32 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
1: buy the 3m vhb tape locally. amazon should be ok, but i learned the hard way, it's such desirable tape that many vendors stock counterfeit-and-inferior double sided tapes without even knowing it. and you won't know the difference until it decides to spontaneously stop hitchhiking on your car.
2: use the 3/4-1" tape.
3: if the bolts are there, i would use them. if you don't want the bolts, get a replica off ebay. my trd-style duck tail was something like $89 pre-painted. all i had to do was apply the tape and stick it on.
Old 03-20-2020, 10:03 PM   #3
SmartedPanda
Hey Thanks!
1. I already have it and tested on other parts, so far so good at 80mph.
2. I'll double up on the sizing.
3. Would the bolts fit into the BRZ holes? I'm pretty sure they don't but not confident.
Would you take off the Toyota weather stripping the 3M that? Most of it is 3M+Weather Stripping combined.
Old 03-20-2020, 10:07 PM   #4
Contender
Drives: 2017 Toyota 86
I put on a TRD tail and used the bolts plus 3m tape. I used the cardboard/paper template for the bolt holes super easy.
Contender is offline   Reply With Quote
Old 03-20-2020, 10:57 PM   #5
soundman98
soundman98's Avatar
Originally Posted by SmartedPanda View Post
Hey Thanks!
yeah, i'm just extremely paranoid about the tape now that i've gotten some crap rolls...
i haven't a clue on the bolt hole-ing. however, i can tell you that this spoiler fits the oem brz spoiler holes perfectly
https://www.ebay.com/itm/Fits-13-20-...72.m2749.l2649
because of that i have a sneaking suspicion that they will likely line up-- subaru and toyota have a pretty decent history of not dramatically changing things just to screw people over(i'm looking at you GM).
the way i would check is to get a large piece of cardboard-- bigger than the spoiler. stab all the bolts through the cardboard, then remove the spoiler, and use the cardboard as a crude template to check the rough bolt location and spacing on the trunk.
Old 04-14-2020, 11:34 PM   #6
saltywetman
Drives: 2020 Toyota 86 GT 6M
don't think it bolts up to stock holes
saltywetman is offline   Reply With Quote
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
The Kiske spoiler, Skyline GT-R R35 Spoiler vs. ebay replica soundman98 Cosmetic Modification (Interior/Exterior/Lighting) 0 02-29-2020 09:53 PM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
Battle Aero Swan Neck Spoiler Paired W/ Rocket Bunny V2 Duck Bill Spoiler Preppy Cosmetic Modification (Interior/Exterior/Lighting) 30 02-10-2017 09:20 PM
BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes? FR-Sizzle Cosmetic Modification (Interior/Exterior/Lighting) 10 09-21-2015 02:29 PM
