Old 03-07-2020, 05:36 PM   #1
hedtrip
hedtrip's Avatar
Drives: 2013 toyota 86
Megan Racing Inner tie rods install /vid
I installed some Megan Racing inner tie rods in my 86.
So i made a video.
So hopefully it makes it easier for someone else doing it.
It is pretty much the same process replacing with the OEM rods
It is not overly hard if you plan ahead.
[ame="https://www.youtube.com/watch?v=vKryb9Om0Rc&t=439s"]https://www.youtube.com/watch?v=vKryb9Om0Rc&t=439s[/ame]
hedtrip is offline   Reply With Quote
The Following User Says Thank You to hedtrip For This Useful Post:
Joveen (03-07-2020)
Old 03-08-2020, 07:20 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Worth noting that wheel rubbing with greater max turning angle possible, and that one should plan in some angle limiting washers/spacers (which will rob a bit meaning from changing out these tie rods), or wheel spacers, and in later case, depending on thickness and eg. slip on spacer type, also longer wheel studs.
Megan racing rear traction rods fcdrifter20 Brakes, Suspension, Chassis 2 07-01-2016 08:49 PM
Used megan racing adjustable traction rods fcdrifter20 Brakes, Suspension, Chassis 1 06-28-2016 01:07 AM
Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc Chase Bays Brakes, Suspension, Chassis 14 02-03-2016 10:14 PM
Cheap! Megan rear toe rods Newlovekid Brakes, Suspension, Chassis 1 05-22-2014 10:13 AM
[Cali] Megan rear toe rods Newlovekid Brakes, Suspension, Chassis 0 04-20-2014 06:24 AM
