Old 03-05-2020, 05:02 AM   #1
qijian
Drives: FRS
Swapping 2016 MT engine into 2013 MT
Just pulled the motor since the one in the 2013 blew. Is the 2016 engine a direct swap into the 2013? Both are MT. Is there anything i need from the 2013 to make it work? I dont need to flash anything to the ECM if im using the old ecm & tranny right?
Not even gonna bother with the 2017+ motors since there a ton of work involved and i just want to get the car running. Then i’ll probably build a engine and slap the turbo back on
qijian is offline   Reply With Quote
Old 03-06-2020, 03:09 PM   #2
Chickeneatman
Drives: 2013 FR-S Ultramarine
Should be a straight easy swap. No need to flash the ECM. If you can grab the trans with the motor as well, that will make it an even easier swap.
I crashed my FRS at the track, bought a BRZ with a spun bearing. I swapped the motor and trans from my FRS to BRZ and had it running on a Monday evening after work.
Chickeneatman is offline   Reply With Quote
The Following 3 Users Say Thank You to Chickeneatman For This Useful Post:
Decimus (03-06-2020), mrg666 (03-08-2020), qijian (03-07-2020)
Old 03-06-2020, 07:20 PM   #3
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Are there issues with trans not working if theyre from different years?
Decimus is offline   Reply With Quote
The Following User Says Thank You to Decimus For This Useful Post:
Opie (03-10-2020)
Old 03-06-2020, 07:50 PM   #4
anticubus
Drives: 2017 Toyota 86
@Dave-ROR and @Opie have dealt with this one and gave us this gem of a post about some harness differences for 2013, 2014, and 2015/16 MYs using newer coilpacks: http://www.ft86club.com/forums/showp...2&postcount=74
anticubus is offline   Reply With Quote
The Following 7 Users Say Thank You to anticubus For This Useful Post:
Dave-ROR (03-06-2020), Decimus (03-11-2020), Lonewolf (03-14-2020), mrg666 (03-08-2020), Opie (03-10-2020), qijian (03-07-2020), wparsons (03-10-2020)
Old 03-06-2020, 09:15 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Nope. Just a little work involved if swapping over some parts or removing them if your replacement engine didn't have the same transmission option. Manuals just have a block-off plate.
The Following 4 Users Say Thank You to Kiske For This Useful Post:
Chickeneatman (03-10-2020), Decimus (03-11-2020), Opie (03-10-2020), qijian (03-07-2020)
Old 03-10-2020, 01:19 PM   #6
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
If the 2016 engine is complete you shouldn't need anything from the '13, it will bolt in and run perfectly. As a bonus you'll get the updated coil packs/harness. Just remember that there are some minor actual part #/harness connector differences between the two engines, so when you go to get engine parts be sure to look up parts for a 2016 not a 2013.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
Decimus (03-11-2020), qijian (03-11-2020)
Old 03-11-2020, 02:39 PM   #7
qijian
Drives: FRS
Thanks everyone for the feedback. I just completed the 2016 engine swap into the 2013 and everything plugged and play. Literally didn't have to change anything.
P.S. I was also able to get a tune for my flexfuel kit too so didn't have to drain all the E85 from the tank.
The Following 4 Users Say Thank You to qijian For This Useful Post:
anticubus (03-12-2020), Decimus (03-11-2020), Jyn (03-12-2020), Lonewolf (03-14-2020)
Old 03-12-2020, 02:07 AM   #8
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Nice. This is the route I want to go with my 2014 when it blows up. Thanks for the confirmation of ease.
Thought about the '17+ motor, but I've heard it's not worth it for all the hassle.
Jyn is offline   Reply With Quote
Old 03-12-2020, 03:05 PM   #9
Opie
Opie's Avatar
'17+ should be plug and play, but may need a tune or a '17+ ECU to make the 2017 power.
Old 03-13-2020, 08:54 PM   #10
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Definitely not plug and play. I spent many hours looking online regarding the differences and concluded you have to take apart the timing cover and many other things to swap parts.
I came upon this video, and its very very detailed. Guy uses 2019 engine but swaps over all the 2013 components to make it work. Worth watching if you have the time and need to do the swap.
[ame="http://youtu.be/pqxW9UNMBUU"]http://https://youtu.be/pqxW9UNMBUU[/ame]
EndlessAzure (05-17-2023)
Old 03-14-2020, 06:14 PM   #11
Jyn
Noob
Jyn's Avatar
Unfortunately not plug and play from the various people I've seen do it.
Old 03-14-2020, 06:15 PM   #12
Jyn
Noob
Jyn's Avatar
in case it doesn't show for others. I had to click reply to see the YouTube link.
The Following 2 Users Say Thank You to Jyn For This Useful Post:
Decimus (03-15-2020), Hypnocracy (03-19-2020)
Old 03-18-2020, 02:23 PM   #13
knucklehead
Drives: FRS
I know you say that if the one could get the transmission it would make the swap easier. Other than separating the engine from the transmission, is there an issue, say with the computer having to be reprogrammed/flashed, etc.?
Reason I ask is that I am in the same boat that I have a spun bearing and need a replacement motor. I have a 2013 FRS and am able to locate a 2015 motor (not planning on getting the tranny). Just researching to ensure that
this is possible with no issues.
knucklehead is offline   Reply With Quote
2016 frs engine Doctordiode Engine Swaps 18 06-19-2020 01:28 AM
WTB: (CA) 2013-2016 FRS BRZ Engine Decimus Want-To-Buy Requests 0 02-28-2020 02:21 PM
The most expensive part of engine swapping; software. Why? AutoNewb Engine Swaps 16 11-23-2019 05:55 PM
Engine swapping my first car. MK42Dragon Engine Swaps 23 04-01-2018 07:55 AM
Need help with swapping engine FRS frsnick Engine, Exhaust, Transmission 16 05-11-2016 04:09 PM
