Old 02-23-2020, 09:48 PM   #1
FinallyGot
Drives: Brz
Why is it so hard to remove the front badge?
I been trying so hard to get this front badge off my 86. I got the back one off no problem but no matter how much heat i use it wont come off lmao. Any tips?
FinallyGot is offline   Reply With Quote
Old 02-23-2020, 09:49 PM   #2
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
You used a fishing line to cut through the adhesive?
Drifter X is offline   Reply With Quote
Old 02-23-2020, 09:56 PM   #3
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Dental floss
Old 02-23-2020, 10:31 PM   #4
FinallyGot
Drives: Brz
Did all that lmao, finally got it off with goo gone, heat gun, and floss cutting through my fingers
Old 02-24-2020, 12:11 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
you guys work way too hard to get the badges off... mine just come off with the edge of a utility knife.
Old 02-24-2020, 12:43 AM   #6
FinallyGot
Drives: Brz
Must be nice lmaoo
Old 02-24-2020, 12:49 AM   #7
soundman98
soundman98's Avatar
i've never tried the floss option. when i pulled the badges on my 18 year old truck, i used the same technique, though i mostly just cut the badges off with a long snap-blade knife, and then scrubbed/picked the remaining part off with my fingers.
Old 02-24-2020, 03:24 AM   #8
beltax90
beltax90's Avatar
Drives: 2010 corolla
metal backings are pressed into the back of the pegs that line up the badge. plus the adhesive. heat, plastic wire from arts and crafts store, plastic spatula, goo gone works well.
beltax90 is offline   Reply With Quote
Old 02-24-2020, 09:28 AM   #9
jordan7831
Drives: 2016 Halo FRS
Next time tie the floss around a wooden dowel or pen to form a make shift garotte. This will avoid hurting your fingies.
Originally Posted by Mr.ac View Post
My butt dnyo didn't like it
jordan7831 is offline   Reply With Quote
The Following 2 Users Say Thank You to jordan7831 For This Useful Post:
Drifter X (02-24-2020), tarzan_nojane (02-26-2020)
STI FRONT GRILLE BADGE xenarc Cosmetic Modification (Interior/Exterior/Lighting) 6 07-11-2018 09:33 PM
How hard is it to remove the engine? ChrisD Engine, Exhaust, Transmission 17 07-29-2015 10:27 PM
how to remove hard water spots DarkestBuddha Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 08-10-2014 06:53 PM
how hard to remove tpms sensor? hanabie Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-04-2013 05:46 PM
DIY remove FR-S 86 badge and installing JDM 86 badge Tylub DIY (Do-It-Yourself) Guides 13 07-07-2013 10:24 PM
