Drives: 6MT '15 BRZ | '89 240sx (sold...)
lug nuts/hub centric rings for SSR GTX01?
Hey guys, I've got a set of SSR GTX01s (17x9.0 +38) incoming and I was wondering if there was a way to figure out what lug nuts will go with them? I've read that there are clearance issues with certain products out there and I'd rather not do trial and error if possible.
I also saw on the specs sheet that the center bore is 73mm. I'm guessing that I can just get any ring with a 73mm outer diameter and 56mm inner diameter and I'll be set?
la cocaina is not good for you ig: sad_fa20 |
#2 | |
Drives: 2015 BRZ
Yes, if you plan on getting hub rings you'll need 73mm to 56.1mm. https://www.rallysportdirect.com/par...iABEgL9OfD_BwE Last edited by Vital; 02-18-2020 at 09:27 AM. |
#3 | |
And is there any real compatability issues with 56.0, 56.10, and 56.15? Been seeing a lot of weird sizes on the inner diameter.
la cocaina is not good for you ig: sad_fa20 Last edited by sukumizu; 02-18-2020 at 04:51 PM. |
Rust bucket enthusiast
I know that most people want to be thorough and do everything recommend. I've been fitting lots and lots of aftermarket wheels on a lot of cars and never used these hub rings. I've driven my car's through awful rut filled dirt roads well over the speed limit, through pot hole filled city streets, and never ever had a wheel that was properly balanced and mounted wobble.
Have them mount your tires using the yellow dot, buy quality tires, and enjoy |
Figured that I might as well go the extra length and throw on the rings since they're so cheap.
#6 | |
Country Boy 4 Life
I have had a few balancing issues when not using hubrings, so I ALWAYS use them now. Aluminum are nice, but plastic ones work just fine. (I like the fiber composite ones better than the cheap plastic ones though) They all work. I have ordered from ebay vendors with a high trader rating and have never had a problem with fit. I am running hubrings on all 4 of my vehicles. Three of my cars have spacers, so those have 2 sets of hub rings. (inner and outer on the spacers) Edit: Hubrings are, IMO, more important on a car that uses wheel bolts. The most problems I had was on a benz.
I LIKE TIRES! |
Thanks! 56.1mm it is then...
| Are hub centric rings mandatory? | Impureclient | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 03-03-2019 01:46 AM |
| Hub Centric Rings Fitment? | Hentai | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 09-20-2015 01:42 PM |
| WTB: 65mm to 56.1mm Hub Centric Rings | alexvc | Want-To-Buy Requests | 1 | 01-24-2015 05:57 PM |
| SSR Type C RS hub centric rings | Justkiz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 02-14-2013 08:34 PM |
| FS: Hub centric rings 63 > 56.1 mm | JDMSushi | Australia Classifieds | 3 | 02-09-2013 08:52 PM |
