Old 02-18-2020, 12:24 AM   #1
sukumizu
sukumizu's Avatar
Drives: 6MT '15 BRZ | '89 240sx (sold...)
lug nuts/hub centric rings for SSR GTX01?
Hey guys, I've got a set of SSR GTX01s (17x9.0 +38) incoming and I was wondering if there was a way to figure out what lug nuts will go with them? I've read that there are clearance issues with certain products out there and I'd rather not do trial and error if possible.
I also saw on the specs sheet that the center bore is 73mm. I'm guessing that I can just get any ring with a 73mm outer diameter and 56mm inner diameter and I'll be set?
la cocaina is not good for you
ig: sad_fa20
sukumizu is offline   Reply With Quote
Old 02-18-2020, 08:53 AM   #2
Vital
Drives: 2015 BRZ
You just need to get any aftermarket conical shaped lug nuts. Just make sure they are M12x1.25.
Yes, if you plan on getting hub rings you'll need 73mm to 56.1mm.
https://www.rallysportdirect.com/par...iABEgL9OfD_BwE
The Following 2 Users Say Thank You to Vital For This Useful Post:
Leonardo (02-18-2020), sukumizu (02-18-2020)
Old 02-18-2020, 01:55 PM   #3
sukumizu
sukumizu's Avatar
Cool. How about sizing length wise? Do they all tend to work out?
And is there any real compatability issues with 56.0, 56.10, and 56.15? Been seeing a lot of weird sizes on the inner diameter.
ig: sad_fa20
Old 02-18-2020, 02:15 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I know that most people want to be thorough and do everything recommend. I've been fitting lots and lots of aftermarket wheels on a lot of cars and never used these hub rings. I've driven my car's through awful rut filled dirt roads well over the speed limit, through pot hole filled city streets, and never ever had a wheel that was properly balanced and mounted wobble.
Have them mount your tires using the yellow dot, buy quality tires, and enjoy
Old 02-18-2020, 03:01 PM   #5
sukumizu
sukumizu's Avatar
Figured that I might as well go the extra length and throw on the rings since they're so cheap.
ig: sad_fa20
Old 02-18-2020, 03:29 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
And is there any real comparability issues with 56.0, 56.10, and 56.15? Been seeing a lot of weird sizes on the inner diameter.
Get an inner diameter of 56.1mm
I have had a few balancing issues when not using hubrings, so I ALWAYS use them now.
Aluminum are nice, but plastic ones work just fine. (I like the fiber composite ones better than the cheap plastic ones though) They all work. I have ordered from ebay vendors with a high trader rating and have never had a problem with fit.
I am running hubrings on all 4 of my vehicles. Three of my cars have spacers, so those have 2 sets of hub rings. (inner and outer on the spacers)
Edit: Hubrings are, IMO, more important on a car that uses wheel bolts. The most problems I had was on a benz.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
sukumizu (02-18-2020), Vital (02-19-2020)
Old 02-18-2020, 07:00 PM   #7
sukumizu
sukumizu's Avatar
Thanks! 56.1mm it is then...
ig: sad_fa20
The Following User Says Thank You to sukumizu For This Useful Post:
Vital (02-19-2020)
Are hub centric rings mandatory? Impureclient Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-03-2019 01:46 AM
Hub Centric Rings Fitment? Hentai Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-20-2015 01:42 PM
WTB: 65mm to 56.1mm Hub Centric Rings alexvc Want-To-Buy Requests 1 01-24-2015 05:57 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
