Old 02-06-2020, 09:58 PM   #1
SamtheKorean
September
SamtheKorean's Avatar
Drives: 2015 BRZ
Hesitation on EL Long tube headers
Hey guys I'm currently running a Nameless Long Tube EL headers with off the shelf OFT stage 2+ tune. Def getting more power top end but getting Hesitation/ flat spot on 3-4k rpm. It's pretty noticeable slow on that range and as soon as it goes over 4k dramatic change in power. any tune changes i can make on this issue? like valve timing or fueling etc..?
SamtheKorean is offline   Reply With Quote
Old 02-06-2020, 10:08 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Torque dip absolutely still present with the Nameless header without custom tuning. Even with custom tuning it is weak in the midrange compared with an ACE or JDL. You can tweak the AVCS to improve it a bit but it is still going to be meh till 4k, then it wakes up.
https://www.ft86club.com/forums/showthread.php?t=70141
The Following User Says Thank You to NoHaveMSG For This Useful Post:
SamtheKorean (02-06-2020)
Old 02-06-2020, 11:01 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
If you do feel inclined to adjust your AVCS you can use these settings that have already been worked out.
http://www.ft86club.com/forums/showp...0&postcount=56
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Old 02-06-2020, 11:05 PM   #4
SamtheKorean
September
Drives: 2015 BRZ
oh sweet! but if you were the one who was doing it would you make those changes? am i looking at a better result than just running the ots tunes?
Old 02-06-2020, 11:07 PM   #5
PulsarBeeerz
I certainly would. The guys that came up with them know their stuff.
SamtheKorean (02-07-2020)
Old 02-07-2020, 12:56 AM   #6
SamtheKorean
September
Drives: 2015 BRZ
would def try soon, ill keep the update on this thread so if anyone is going similar setup ill try to give my best from the butt dyno
PLM Long Tube Header interna Engine, Exhaust, Transmission 350 08-16-2019 12:22 PM
Who makes 4-1 long tube headers? Dr. BRZ Engine, Exhaust, Transmission 13 03-26-2018 08:24 PM
Long tube catted headers possible? wparsons Engine, Exhaust, Transmission 6 01-31-2014 10:56 AM
New 4-2-1 Long Tube Header Anorexic 86 Engine, Exhaust, Transmission 28 08-25-2013 04:28 PM
