Old 01-30-2020, 02:44 PM   #1
Chuckable
Drives: 2017 Toyota 86
Edelbrock SC kit compatibility with Greddy oil cooler?
Probably mostly dreaming here, but considering purchasing an Edelbrock kit for my 2017 86.
After reading through the installation manual, it appears that the heat exchanger and electric pump may interfere with the Greddy oil cooler kit I already have installed.
For reference, here are some pictures of the oil cooler setup.
Can anyone provide any insight on this? Thank you!
Chuckable is offline   Reply With Quote
Old 01-30-2020, 03:58 PM   #2
wparsons
wparsons's Avatar
@CSG Mike - did CSG have that combination? I think one of the cars has had a greddy oil cooler, and know one had the edelbrock, just not sure if it was the same car at the same time.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Chuckable (01-30-2020)
Old 01-31-2020, 12:20 AM   #3
You'll need to modify the bracket, but it *can* work with modification.
wparsons (02-06-2020)
Old 01-31-2020, 12:27 AM   #4
Chuckable
Thanks for that input. Which bracket? The heat exchanger or mount for the pump?
Old 01-31-2020, 12:38 AM   #5
The bracket for the oil cooler, as it wants to occupy the same space as the Edelbrock LTR. You need to push it forward a bit.
HKS oil cooler with Edelbrock SC Zee7 Forced Induction 5 07-10-2019 03:44 AM
CSG Forced Induction - Edelbrock | Jackson Racing | GReddy CounterSpace Garage Forced Induction 3 01-20-2019 07:23 PM
P&L Turbo Kit Oil Cooler Compatibility enjoyminutemaid Forced Induction 4 05-15-2014 03:41 PM
Intake/Oil Cooler compatibility test D1cker Engine, Exhaust, Transmission 3 03-30-2013 08:16 PM
