Old 01-30-2020, 01:18 AM   #1
haute
Drives: 37J
Unique situation with my car. Please tell me what you think.
2014 Automatic Scion FRS 83K miles.
My car's RPM dips when I brake with medium effort. My idle RPM is ~750 but when I brake, it drops down to around ~550. Because of this, the headlights flicker.
Now hear me out, this ONLY happens when the car is warmed up and when I brake in drive. When I just let the car coast to a stop, it doesn't happen until I brake. When I switch the gear to neutral and brake, it does not happen. When the car is cold (first 10 minutes of starting my car in the morning) it does not happen. It ONLY happens when the car is warm and in drive.
What the hell does this problem sound like? Could auto trans fluid change fix this? Could it be a dying battery? I don't have a problem with starting my car in the cold (~15 fahrenheit).
No CEL's. No TSB's.
I'm lost and any help or ideas of what it could be would help.
Small log of just the idle drop: https://datazap.me/u/nancyle/rpm-drop
Longer log of regular driving: https://datazap.me/u/nancyle/longer-drive
haute is offline   Reply With Quote
Old 01-30-2020, 02:05 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I have a similar issue and so does another AT twin owner I know. Mine can be so bad the car dies at times under hard braking.
We both are under the assumption its a bad air pump. But the part is not exactly cheap so neither one of us have bought a new one to swap it and see yet lol
I would also check air filter and clean your maf possibly as well.
Old 01-30-2020, 02:09 AM   #3
haute
Drives: 37J
How similar is your problem? By air pump, do you mean the vacuum pump?
Old 01-30-2020, 02:39 AM   #4
finch1750
finch1750's Avatar
Yeah, I knew that wasn't the right part when I wrote it but couldn't think of the right name.
Mostly my car will bog from low RPM under moderate braking at times (not every time). Under hard braking my car has even stalled before due to the RPM dropping really low. This only happens when I come to a complete stop, if I am just decelerating i haven't noticed anything out of the ordinary on a regular enough basis to say it's related.
Old 01-30-2020, 03:52 AM   #5
Boomerang
86
Boomerang's Avatar
Manual > Auto
fixed
The Following 5 Users Say Thank You to Boomerang For This Useful Post:
86MLR (01-30-2020), DandoX (01-30-2020), korhun (01-30-2020), MasterBandit (01-30-2020), soundman98 (01-30-2020)
Old 01-30-2020, 06:21 AM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Anytime you've got dipping idle problems on any car, it's a bad idea to not check the throttle body for carbon deposits first. I'm not saying that it's 100% your problem, but it's such an easy, simple DIY thing to check that any car benefits from, it's just smart to start there.
Then, know that the vacuum pump is doing *something* with the air it's pumping, and that is sending it inside the crankcase, so when you brake, you're sending a shot of unmetered air into the crankcase, which gets sucked into the PCV and into the intake. If your MAF is dirty and already reading low g/sec, that incoming bypass of air might be "too much for comfort". While you've got your can of carb cleaner for the throttle (which you should only cleaned by hand with a cleaner-soaked rag, and not by spraying it directly), take the MAF off and give 'er a squirt.
If the vacuum pump wasn't working, you wouldn't have braking assist, it doesn't seem plausible that the pump would be working too much, so it's safe to assume the pump is fine.
Old 01-30-2020, 07:20 AM   #7
JIM THEO
Drives: BRZ 2018
Exactly, throttle body for carbon deposits, MAF problem (usually for cars equipped with cone filter), bad battery as your lights flicker etc
JIM THEO is offline   Reply With Quote
Old 01-30-2020, 09:54 AM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This happenes to me too. Just very rarely. Don't think it is carbon build up, as it happened to me with less than 1000 on my odometer. It is always weird when it happens, but for me it has only stalled once. Mostly it just almost dies, then seems to run fine. And then it does not happen again for a while on my car.
2013 AT 81,000 miles.
I LIKE TIRES!
Old 01-30-2020, 01:07 PM   #9
Stomachbuzz
Drives: 2013 FRS
these cars have a vacuum pump?
Or are you talking about a classic vacuum leak?
Stomachbuzz is offline   Reply With Quote
Old 01-30-2020, 01:12 PM   #10
kev0
Drives: '14
AT's have vacuum pumps!
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
Stomachbuzz (01-30-2020)
Old 01-30-2020, 01:26 PM   #11
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Sorry, not sorry.. Stop doing this, your transmission is designed to brake in drive.
https://mechanics.stackexchange.com/...hing-stops-bad
Although, since this can be accomplished with paddle shifters, perhaps accidentally shifting into Reverse is not a problem here. I'd argue from a safety standpoint, if you needed to accelerate in an emergency situation, remaining in drive would make you go ZOOOOOOM (getting out of the way), instead of going ZINGGGG (revving on a neutral transmission). Carry on.
ROFL it's Waffle is offline   Reply With Quote
Old 01-30-2020, 01:28 PM   #12
Stomachbuzz
Drives: 2013 FRS
Oh wow. That's interesting.
Thanks
Old 01-30-2020, 02:52 PM   #13
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Originally Posted by RZNT4R View Post
While you've got your can of carb cleaner...
Do NOT use carb cleaner on your throttle body or to clean your MAF. They sell specific throttle body cleaner for a reason. Carb cleaner is extremely caustic.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
Tcoat (01-30-2020)
Old 01-30-2020, 03:46 PM   #14
As Kev said the ATs do the MTs do not. There is also quite a history on here of the pumps on the 13s and 14s failing so I wouldn't rule it out.
weird situation zizon93 BRZ First-Gen (2012+) — General Topics 30 09-19-2017 09:30 PM
San Jose cop situation help taylorsankey Northern California 33 08-17-2014 12:45 PM
Tire situation jarviz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 11-06-2013 04:55 PM
My situation MR WHAAKAKA Scion FR-S / Toyota 86 GT86 General Forum 31 05-22-2013 03:14 PM
