Old 01-17-2020, 10:12 PM   #1
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Crawford power blocks question
Yes I searched.
Any benefit of power blocks if I am already at stage 2 tune with header and full exhaust. No plans for FI, just thinking about maximizing the power.
Anyone have some opinions, hopefully based on experience.
Ernest72 is offline   Reply With Quote
Old 01-17-2020, 10:37 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
not worth the 200 bucks
short answer
long answer is being discussed elseware
I feel it helps move down the torque dip and coupled with 4.3 gears allows the car when already passed 4000 rpm to stay in peak torque to power range.
but ultimately the stage two and header make the torque dip null.
Clutch Dog is offline   Reply With Quote
Old 01-17-2020, 10:56 PM   #3
Ernest72
short answer
Thanks that is what I thought. If it was cheaper maybe.
Old 01-17-2020, 11:16 PM   #4
Lantanafrs2
Drives: 2013 frs red
Mine work well for me. More useable torque in midrange.
Old 01-17-2020, 11:44 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
If no access to E85, BPB is a decent NA mod. You’ll probably want a custom tune to maximize the benefits. custom tune should also have slight gains from stage 2 ots tune with just a header but even more beneficial if you add BPB into the mix.
Old 01-18-2020, 09:18 AM   #6
Ernest72
Do you have a header and tune?
Old 01-18-2020, 09:20 AM   #7
Ernest72
So now it’s 200 plus a tune which is another 200 minimum for an Etune or more 4-500 for Dyno tune. Would you say the difference is worth it for that kind of money?
Old 01-18-2020, 10:32 AM   #8
86TOYO2k17
The custom tune will bring a little more power out of your setup without the blocks. And be even more worth it to custom tune with the blocks.
If something is “worth it” is entirely subjective to the individual. I would say yes get BPB + tune, others would say no.
To overly simplify it to be easier to decide BPB may add 2-3% more gains and custom tune may add another 2-3%. It doesn’t sound like a lot but with NA modding every last little HP counts.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Ernest72 (01-18-2020)
Old 01-18-2020, 10:52 AM   #9
Lantanafrs2
Yes
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 01-18-2020, 10:52 AM   #10
Ernest72
I hear you. Just thinking I can spend that money on mountain bikes and other things. Thanks.
Old 01-18-2020, 12:10 PM   #11
bfrank1972
Drives: 2013 FR-S Argento
That's always the case - you could have said that about your exhaust and tune $$$ They're definitely worth it if you are doing all the bolt-ons and planning on staying NA and pump gas. They beef up the upper-midrange and are a nice compliment to headers (which usually flatten out the lower range). As with anything on this car (aside from FI) no bolt-ons are going to make it a rocket
bfrank1972 is offline   Reply With Quote
Old 01-24-2020, 08:56 AM   #12
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
I recently had this installed on my FRS that already has FT86 Speedfactory UEL headers & OFT tune for about 2 years now. IMO, it's a great addition as it has become more alive & I can really feel it pulling at 3K rpm where it matters for my daily driver setup.
I think BPB is way better investment than upgraded air filter/intake.
If I were to do my mods all over again for daily driving with staggered budget in mind, my sequence for engine upgrades would be UEL-BPB-OFT tune-aluminum driveshaft.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Crawford Power Blocks Xbk47 Engine, Exhaust, Bolt-Ons 5 05-31-2019 11:43 AM
e85 and Crawford power blocks Lantana frs Engine, Exhaust, Transmission 10 07-21-2018 12:34 PM
Crawford Power Blocks absolute Engine, Exhaust, Bolt-Ons 3 05-17-2015 12:21 PM
Crawford power blocks fs Triumphrider Engine, Exhaust, Bolt-Ons 2 04-06-2015 12:17 PM
Crawford Power Blocks like new oTaGGeDo Engine, Exhaust, Bolt-Ons 0 07-27-2014 10:22 AM
