Old 01-15-2020, 09:57 PM   #1
kev0
Drives: '14
Is this a bad battery or a typical cold weather E85 start?
https://streamable.com/93cpn
I've watched some videos of cold E85 startups such as
to compare to mine but my tachometer moves unlike this one in the video.
Does mine seem like a bad battery or is it a typical cold weather E85 start? I'm asking to narrow down the cause of my CEL's.
Also on the topic of battery, does my battery seem like the stock ones that come with our cars from the factory?
kev0 is offline   Reply With Quote
Old 01-15-2020, 10:17 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
[IMG]blob:https://imgur.com/07e81747-52fb-44aa-b9a1-56c075c00ea6[/IMG]
Is it a panasonic battery? Your link didn't work so we can't see. If it is it's 6 years old and time for a new a nice new one with high CCAs
Also what were the ambient temps? I can start find just with a few extra "turn overs" in around 30-45 Fahrenheit but my car has had a lot of tweaks to its tune via romraider.
Old 01-15-2020, 10:22 PM   #3
kev0
Drives: '14
Ah, no it's an Autocraft Silver 35-1.
This cold start was around 30 Fahrenheit. Does yours behave like mine does when you say 'turn overs'?
Old 01-15-2020, 10:36 PM   #4
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
From that video, it looks like your throttle body wasn't opening enough to keep the RPMs up for cold start, and the ECU couldn't figure it out before it stalled.
Did you give it any throttle on second start up, or was that ECU controlled?
Colder temps require different fuel especially at start up. It could just be the ECU learning. If this has started happening at the same time temps have been dropping, I might say it's normal, but the ECU should learn very fast.
My only other thought is to check your throttle body for carbon build up, and clean if its dirty. Expect some more hiccups after cleaning while everything relearns, but it shouldn't be more than one or two drives worth.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 01-15-2020, 10:53 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
No it is not the stock battery.
Old 01-15-2020, 11:19 PM   #6
kev0
Drives: '14
Thanks for the insight. It was all the ECU. I was not giving it throttle. You might be onto something about the throttle body not opening. My RPM drops when I brake sometimes. Do you know what I should to remedy the problem? Just buy Seafoam and spray it inside the TB?
Old 01-16-2020, 09:14 AM   #7
ActionMaxon
I've never used seafoam personally. Not for any reason in particular, just haven't.
I would use a cleaner specifically for throttle bodies. Thr stuff I use is made by 3M and comes in a little black can. Spray it onto a rag, and then wipe the throttle body down till clean. The carbon build up cleans easily.
You could spray directly onto it, but the TB is coated with a non stick type coating so more gentle is better. Spraying onto it could cause more hiccups and misfires when you go to restart. It will clear out though so not a huge deal.
After that use a scanner to clear codes. This will reset adaptive values and your ECU will relearn where to put the throttle blade at any given time. The first couple startups may result in a stall and the first test drive or so may display some unusual idle characteristics, but it should figure itself out very fast.
If you don't have a scanner, disconnect the battery for a half hour, then reconnect.
Usually when I do something like that, when getting the car to relearn faster, once it's idling normally, I add loads and vary the RPM, (bring RPMS to like 3000, then release throttle and allow engine to idle. It may bog down, then should correct itself. If it stalls, just start engine again and repeat.) turn the A/C on, turn headlights on with highbeams, put both window switches in "up" position for a couple seconds when the windows are already up. (This will load up the alternator).
Once it's running on its own standing still go on a test drive, shut it down, start back up and drive again. After that if the car isn't figuring things out it's likely some other issue.
2016 Oceanic
Old 01-16-2020, 07:58 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
your primary issue is that your car appears to be upside down.
automobiles generally work best with the rubber wheels facing towards the strongest local gravity source.
Old 01-17-2020, 01:22 AM   #9
FRSBRZGT86FAN
If you've got an e85 tune then you definitely should get some edits done to the tune at low ambient to help out, steve99 and wayno on this forum had some very helpful edits I used.
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 12:55 PM
Question about cold start knock, battery radroach Issues | Warranty | Recalls / TSB 24 12-17-2016 08:24 AM
Cold weather start oppiee CANADA 57 01-16-2015 03:20 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
