Drives: 2015 FRS
Never too old to enjoy a neat little car.
Purchased my '15 FRS two years ago, and absolutely love the car. I've always been a pretty self-sufficient car guy, and had two pretty decently modified 240SXs before departing that scene with the FRS. After driving the FRS for a year, and learning about the car, I put some wider wheels and tires on it, set camber, did some combination aftermarket/home fabrication to lower and coil-over it, and did the rear Valenti light thing. It's a daily driver, that makes every day that I drive the car a worthwhile day, no matter how crappy the rest of the day seems to be. One of my goals will be to build some fiberglass body components that fulfills some of my vision for the car. I like the Fujimura Rocket Dancer 86 front bumper, but after that, I'm not so impressed with any other aftermarket offerings. I'm probably out of touch with the normal age group for this forum (I'm 63 years old), but that doesn't keep me from appreciating a well handling, sharp looking, and well focused vehicle. I do some track time with another car I built, so I can appreciate the performance of this awesome little "inertia" car. Some of the modifications I've done thus far:
1) Modified OEM rear control arms with 3mm steel, to lower the shocks by one inch so that I could lower the car 1" and still have OEM shock travel (which is surprisingly short or nearly nonexistent before hitting the bump stops). 2) Modified the OEM front strut by cutting off the bottom of the tube, extending it 1", and then installing yellow KONI sport inserts, allowing me to lower the car and still have sufficient shock travel prior to bump. 3) Installed the Ground Control coilover kit to all four corners, using an 8" 225 lb/in" front (recently increased from a 7" 200lb/in spring), and 250 lb/in rear (basically remove the OEM perches, and slip threaded tubes over the top). 4) Installed the Ground Control camber plates at the front. 5) Installed adjustable camber bolts at the front. 6) Installed the Valenti rear lights, and re-wired the Valenti 4th brake light to keep the "V" lit along with the running lights, and use the triangle for a 4th brake light only. 7) Installed Apex ARC-8 17x9 wheels and Michilin Sport Pilot S2 tires. 8) Installed an aftermarket rear backup camera. Looking forward to many years of fun with the car, and hoping I can still get in and out of it during those years. Can't dump a bunch of money in the car, but felt the above mods were the best bang for the buck, and has improved the feel and performance of the car tremendously. The 225 spring up from was the most recent change, and stabilized the car, improved the feel (almost perfectly balanced now), but the changes now are of diminishing returns for a daily driver. On to cosmetic stuff, and maybe a header to address the torque dip and gain a small piece of power. Last edited by blueovalz; 01-12-2020 at 04:37 PM. |
| The Following 3 Users Say Thank You to blueovalz For This Useful Post: |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Header and tune does wonders. These cars are a blast despite being relatively slow. Enjoy it.
Because compromise ®
Drives: Red Herring
| Neat customization site | Impureclient | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-04-2015 05:05 AM |
| Neat aerodynamics video | jeepmor | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 12-14-2014 12:17 AM |
| Neat outline drawings - FRS BRZ 86 | PMok | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 09-24-2012 05:21 AM |
| Good detailer neat Atl, GA | Bg8780 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-20-2012 05:59 PM |
