MASSIVE Part Out (Grr Racing)
Here's a giant list of what I have with prices. Prices do not include shipping.
All photos can be found at: https://www.facebook.com/michele.abb...7703108&type=3 https://www.facebook.com/michele.abb...3148418&type=3 OEM direct injectors 100 for all 4 new OEM injector o rings 10 for all DW injector harness 10 OEM fuel pump with harness 40 RF wheel bearing in hub 40 o2 sensor 50 New Mishimoto upper radiator hose 20 used OEM upper radiator hose 10 New Mishimoto water reservoir hose 10 used OEM water reservoir hose 5 New Edelbrock supercharger intercooler fittings 20 LED interior lights 10 OEM crank position sensor 20 OEM knock sensor 20 OEM cam position sensor 90 degree 40 OEM cam position sensor 40 used Edelbrock supercharger water pump 80 OEM head gasket 40 NRG short hub adapter 80 OEM fuel crossover hose line 10 OEM port injectors 100 OEM driver side fuel rail 30 OEM passenger side fuel rail 30 OEM fuel hardline 20 OEM engine harness 120 OEM wheel speed sensor 10 Factory Subaru D6S spray paint 20 OEM fender support bracket Driver side 20 ACT 6 puck unsprung clutch with lightweight flywheel and pressure plate (slightly used) 300 OEM Misc. engine pulleys 10 OEM motor mount plates 5 OEM altenator pulley cover 5 New Edelbrock 15821 3.25" supercharger pulley 20 OEM driver side C pillar 20 OEM passenger side C pillar 20 OEM passenger side PP-TD16 C pillar panel quarter trim 20 OEM driver side PP-TD16 C pillar panel quarter trim 20 OEM 2013-2014 Scion FR-S FRS Subaru BRZ RH Passenger Side Rear C Pillar Panel Quarter 94013CA 20 OEM 2013-2017 Scion FR-S Dash Trim End Cap Right Passenger RH OEM FRS BRZ 13-17 s15302050 20 2013-2017 Scion FR-S Dash Trim End Cap Right Passenger LH OEM FRS BRZ 13-17 20 OEM Shifter trim (light scratches) 15 OEM 2013-2017 Scion FR-S Center Console Trim Cover Left Driver LH OEM FRS BRZ 13-17 66241CA010 20 OEM 13 - 16 Subaru OEM BRZ REAR RH C PILLAR TRIM COVER PANEL 94013CA020 20 OEM driver side door harness 25 OEM passenger side door harness 25 OEM 2013-2017 Scion FR-S Weather Strip Trim Cover Right Passenger RH FRS BRZ 13-17 63563-CA000 20 OEM 13-15 SCION FR-S SUBARU BRZ DRIVER LEFT DOOR WEATHER STRIP COVER 63563-CA010 20 Custom Grr Racing FA20 long block engine stand with wheels/casters 45 Amsoil Oil Filter 10 Wix extra capacity oil filter 15 2x Swift Springs 7" ID 60mm / 2.37" 560 lbs 10 kg 60 2x Swift Springs 6" ID 60mm / 2.37" 504 lbs 60 2x AST Suspension Springs 6" ID 60mm / 2.37" 560 lbs 10 kg 60 2x AST Suspension Springs 7" ID 60mm / 2.37" 672 lbs 60 2x AST Suspension Springs 7" ID 60mm / 2.37" 448 lbs 8 kg 60 OEM Sway bar Endlinks Rear 20 OEM Rear Lower control arm 50 OEM D4S Engine cover 20 OEM Exhaust hanger 10 OEM tensioner assembly with pulleys 50 OEM Engine oil cap 5 OEM Timing Chain Guides 40 OEM Timing Chain Tensioner Set 40 OEM Transmission/engine cover plate 5 New OEM Driver side rear bumper bracket 57707CA110 10 OEM Engine Wiring Harness bracket 10 New OEM Cam Shaft bolt 13199AA120 2 OEM Oil Pan Drain Plug 5 OEM Timing Chain Sprocket 20 OEM PCV hose 5 OEM Throttle Body Coolant Line 5 OEM crank position sensor wheel 20 OEM Oil Control Valve Sensor 20 OEM Coolant Hardline 10 OEM High Pressure Fuel Pump 40 Mishimoto gutted race t-stat 5 OEM Timing chains (used -id recommend buying new... but I dont judge) 20 OEM head studs (used -id recommend buying new... but I dont judge) 10 OEM Crank position sensor bracket 5 OEM engine bracket for valve cover 5 OEM High pressure fuel pump hard line 5 OEM Coolant line block adapter 5 OEM Engine coolant hard line 5 OEM Cast Coolant passage with fuel rails and temp sensor 150 OEM Cast Coolant passage and temp sensor 80 Continental edelbrock belt 4060995 10 GTSpec subframe reinforcement panels (new) 200 Berk muffler delete with turn out to passenger side 100 OEM LSD (3,000 miles) 220 OEM trailing arm 30 OEM Tensioner assembly 50 New injector hard connectors 40 Valve Shims 5 each OEM Brake Lines 20 OEM Driver side caliper (ripped dust boot) 40 OEM Engine case 250 used w3 rears 80 used porterfield front 100 like new PFC full set 100 used OEM Head bolts 10 used Cometic head gasket 20 OEM Thermostat housing 20 OEM water pump and pulley 40 OEM HPFP Hard line 10 OEM timing chains (used) 30 OEM HPFP hard line 10 Used OEM stock rings 20 OEM Used valve springs 150 OEM Used pistons with rods 30 OEM Used Valves 10 OEM Used rear brake rotors (can be cut) 15 OEM Used front rotors (can be cut) 40 OEM Used 4.10 final ring and pinion gear 140 OEM NEW Lower radiator core support 80 drift front chromoly bash bar 80 OEM Rear suspension 100 OEM trailing arm 30 OEM Rear lower control arm 50 OEM Front sway bar with endlink 20 OEM rear sway bar 20 OEM Rear oem crash beam (red) 100 OEM Brake Booster with reservoir 30 OEM Manual pedal assembly (no gas pedal) 50 OEM Radiator core support bracket 10 OEM Passenger side triangle window with frame 60 OEM Weather stripping 40 OEM top of rear seat and hardware (1200 miles like new) 200 Mishimoto (new in box) 16" HD Fan 100 OEM driver door (no dents, but has some scratches) 250 OEM Fans and shroud 100 OEM Header 100 OEM Overpipe 50 OEM Front Subframe brace 30 OEM Mid pipe or front pipe with cat 80 OEM Window controls driver side 30 OEM Window controls passenger side 20 OEM Driver side fog light (no bulb) 40 OEM Coolant Reservoir 20 JDM OEM AC delete bracket 200 OEM shifter foam 10 OEM clutch master slave cylinder 20 Whiteline KDT923 diff kit 30 Whiteline KCA326 Camber kit (new) 100 OEM Alternator Pulley cover 5 Whiteline W63414 trailing arm lower bushing kit 40 OEM Driver side rear seat bottom cushion 80 OEM Intake Manifold 80 OEM Center Console foam 40 OEM Dashboard air ducting 20 OEM AC hard line 10 OEM Dashboard glovebox shell 60 OEM Driver side window rail 20 OEM passenger side window rail 20 OEM rear bumper bracket driver side 20 OEM rear driver side taillight bracket 20 OEM Antenna wire 5 OEM fuel diaper bracket 10 OEM Antenna 20 OEM Rear center carpet bracket and hardware 10 OEM 2013-2017 Scion FR-S Splash Shield Cover Right 56440CA030 BRZ FRS 13-17 20 OEM 2013-2017 Scion FR-S Mud Flap Guard Left Driver LH FRS BRZ 59123CA030 13-17 15 OEM 2013-2017 Scion FR-S Mud Flap Guard Left Driver LH FRS BRZ 13-1759123CA020 15 OEM Air vent 5 Driver side clear side marker with bulb and harness 15 OEM Scissor jack 20 OEM HPFP Hardlines 10 OEM AIR INTAKE CHAMBER W/ HOSE OEM A40CA00 15 OEM Airbag Module 150 OEM Trunk latch 20 OEM DI ECU 22635JB000 with engine bracket 60 OEM Keyless entry ECU with key fob 250 OEM rear window glass 250 OEM 2013-2017 Scion FR-S Fuel Tank Protector Shield Guard Right Passenger BRZ 13-17 42045CA040 20 OEM taillights 75 OEM Power Steering control module and column 160 WedsSport SA-10R 18×8.5 +45 5-100 with used 245/45/18 Nitto NT01 race 1200 WedsSport SA-10R 18×8.5 +45 5-100 with like new 245/45/18 Federal 595 RSRR 1450 Thanks. If you cannot find the photo, or would like to request more photos please text me for fastest response. seven zero 2 five four 1 five 3 seven one.
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
| The Following User Says Thank You to MicheleAbbate For This Useful Post: | trueno86power (04-24-2020) |
Would like to purchase "OEM Driver seat and headrest (mint condition 1200 miles) 250". Just sent you a text, thanks.
| The Following User Says Thank You to MINI135i For This Useful Post: | MicheleAbbate (01-12-2020) |
Drives: 2014 BRZ - WRB
What kind of ss brake lines are they? Is it the full set or just front/rear?
Thanks! |
#4 | |
Sent from my SM-N960U using Tapatalk
list has been updated.
SS Brake Lines
Any update on what brand brake lines? Would you be willing to sell just the fronts, or only the full set?
Thanks!! |
#7 | |
bump
PM sent lug nuts/brake lines
#10 |
Drives: 2016 FR-S
Does the oil cooler need lines and a sandwich plate or are they included? Thanks!
#11 |
sorry for the delay. responded to all PMs
#12 |
Bump
#13 |
bumpppp
#14 |
Drives: 2013 Scion FRS
Bump for GrrRacing.
| The Following User Says Thank You to Vinhooo For This Useful Post: | MicheleAbbate (07-08-2020) |
| MASSIVE PART OUT (Grr Racing) | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 22 | 05-21-2020 08:08 PM |
| Massive PART OUT (Aimgain, TRD, carbon fiber) | slyder | Exterior Parts (Aero, Lighting, Etc.) | 9 | 10-08-2016 11:25 PM |
| Come watch racing, or be part of it, this weekend (May 16/17). | rice_classic | Northwest | 1 | 05-12-2015 07:55 PM |
| Part numbers for 86 Racing parts | Surok | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 09-20-2013 12:22 AM |
| Road racing, be a part of it for free. | rice_classic | Northwest | 0 | 03-03-2013 04:04 PM |
