Old 12-30-2019, 10:48 PM   #1
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
MASSIVE PART OUT (Grr Racing)
Here's a giant list of what I have with prices. Prices do not include shipping.
All photos can be found at:
https://www.facebook.com/michele.abb...7703108&type=3
https://www.facebook.com/michele.abb...3148418&type=3
OEM direct injectors 100
new OEM injector o rings 10
DW injector harness 10
OEM fuel pump with harness 40
RF wheel bearing in hub 40
o2 sensor 50
New Mishimoto upper radiator hose 20
used OEM upper radiator hose 10
New Mishimoto water reservoir hose 10
used OEM water reservoir hose 5
New Edelbrock supercharger intercooler fittings 20
LED lights 10
OEM crank position sensor 20
OEM knock sensor 20
OEM cam position sensor 90 degree 40
OEM cam position sensor 40
Black lug nuts with key 20
used Edelbrock supercharger water pump 80
OEM head gasket 40
NRG short hub adapter 100
OEM fuel crossover hose line 10
OEM port injectors 100
OEM driver side fuel rail 30
OEM passenger side fuel rail 30
OEM fuel hardline 20
OEM engine harness 120
OEM wheel speed sensor 10
Factory Subaru D6S spray paint 20
OEM fender support bracket Driver side 20
ACT 6 puck unsprung clutch with lightweight flywheel and pressure plate (slightly used) 300
OEM Misc. engine pulleys 10
OEM motor mount plates 5
OEM altenator pulley cover 5
New Edelbrock 15821 3.25" supercharger pulley 20
OEM driver side C pillar 20
OEM passenger side C pillar 20
OEM passenger side PP-TD16 C pillar panel quarter trim 20
OEM driver side PP-TD16 C pillar panel quarter trim 20
OEM 2013-2014 Scion FR-S FRS Subaru BRZ RH Passenger Side Rear C Pillar Panel Quarter 94013CA 20
OEM 2013-2017 Scion FR-S Dash Trim End Cap Right Passenger RH OEM FRS BRZ 13-17 s15302050 20
2013-2017 Scion FR-S Dash Trim End Cap Right Passenger LH OEM FRS BRZ 13-17 20
OEM Shifter trim 15
OEM 2013-2017 Scion FR-S Center Console Trim Cover Left Driver LH OEM FRS BRZ 13-17 66241CA010 20
OEM 13 - 16 Subaru OEM BRZ REAR RH C PILLAR TRIM COVER PANEL 94013CA020 20
OEM driver side door harness 25
OEM passenger side door harness 20
OEM 2013-2017 Scion FR-S Weather Strip Trim Cover Right Passenger RH FRS BRZ 13-17 63563-CA000 20
OEM 13-15 SCION FR-S SUBARU BRZ DRIVER LEFT DOOR WEATHER STRIP COVER 63563-CA010 20
Custom Grr Racing FA20 long block engine stand 40
Mishimoto MMOC-19 Oil Cooler used 100
Mishimoto Oil Lines (new) 80
Amsoil Oil Filter 10
Wix extra capacity oil filter 15
Swift Springs 7" ID 60mm / 2.37" 560 lbs 10 kg 60
Swift Springs 6" ID 60mm / 2.37" 504 lbs 60
AST Suspension Springs 6" ID 60mm / 2.37" 560 lbs 10 kg 60
AST Suspension Springs 7" ID 60mm / 2.37" 672 lbs 60
AST Suspension Springs 7" ID 60mm / 2.37" 448 lbs 8 kg 60
AST Suspension Springs 7" ID 60mm / 2.37" 392 lbs 60
AST Suspension Springs 7" ID 60mm / 2.37" 7k 60
OEM Sway bar Endlinks Rear 20
OEM Rear Lower control arm 50
OEM D4S Engine cover 20
Mishimoto oil lines MMSBH-10-5 80
OEM Exhaust hanger 10
OEM tensioner assembly with pulleys 50
OEM Engine oil cap 5
OEM Engine Motor Mount 41022FJ020 with plate 20
OEM Engine Motor Mount 410221J010 with plate 20
OEM Timing Chain Guides 40
OEM Timing Chain Tensioner Set 40
OEM Transmission/engine cover plate 5
New OEM Driver side rear bumper bracket 57707CA110 10
OEM Engine Wiring Harness bracket 10
New OEM Cam Shaft bolt 13199AA120 2
OEM Oil Pan Drain Plug 5
OEM Timing Chain Sprocket 20
OEM PCV hose 5
OEM Throttle Body Coolant Line 5
OEM crank position sensor wheel 20
OEM Oil Control Valve Sensor 20
OEM Coolant Hardline 10
OEM High Pressure Fuel Pump 40
Mishimoto gutted race t-stat 5
OEM Timing chains (used -id recommend buying new... but I dont judge) 20
OEM head studs (used -id recommend buying new... but I dont judge) 10
OEM Crank position sensor bracket 5
OEM engine bracket for valve cover 5
OEM High pressure fuel pump hard line 5
OEM Coolant line block adapter 5
OEM Engine coolant hard line 5
OEM Cast Coolant passage with fuel rails and temp sensor 50
OEM Cast Coolant passage and temp sensor 80
OEM Rear Crash bar (red) 80
New DBA 4000 series Front Slotted Rotors DBA4650S 250
ACT SB7-HDSS (new never opened) 580
One whiteline (new) KCA435 tie rod and ball joint 40
Continental edelbrock belt 4060995 10
GTSpec subframe reinforcement panels (new) 200
ACE 150 overpipe 300
Berk muffler delete with turn out to passenger side 100
Performance EL header 750
OEM LSD (3,000 miles) 220
OEM Alternator 60
OEM trailing arm 30
OEM Tensioner assembly 50
New injector hard connectors 40
Valve Shims 5
OEM Brake Lines 20
Stainless steel brake lines used but good 50
OEM Driver side caliper (ripped dust boot) 40
OEM Engine case 250
used w3 rears 80
used porterfield front 100
like new PFC full set 100
APR carbon fiber FRS brake ducts for FRS (brand new) 280
Used Mishimoto thermostatic oil cooler sandwich plate 120
used OEM Head bolts 10
used Cometic head gasket 20
OEM Thermostat housing 20
OEM water pump and pulley 40
OEM HPFP Hard line 10
OEM timing chains (used) 30
OEM HPFP hard line 10
Used OEM stock rings 20
OEM Used valve springs 150
OEM used stock main bearings 5
OEM Used pistons with rods 30
OEM Used Valves 10
OEM used cam shafts 60
OEM Used rear brake rotors (can be cut) 15
OEM Used front rotors (can be cut) 40
OEM Used 4.10 final ring and pinion gear 140
OEM NEW Lower radiator core support 80
drift front chromoly bash bar 80
OEM new spare tire 60
OEM Rear suspension 100
OEM trailing arm 30
OEM Rear lower control arm 50
New Mishimoto Oil Cooler bracket 10
OEM Front sway bar with endlink 20
OEM rear sway bar 20
OEM Rear crash beam (black) 100
OEM Brake Booster with reservoir 30
OEM Manual pedal assembly (no gas pedal) 50
OEM Radiator core support bracket 10
OEM Passenger side triangle window with frame 60
OEM Weather stripping 40
OEM top of rear seat and hardware (1200 miles like new) 200
Whiteline BSR54Z 16mm 3 way adjustable sway bar(brand new in box never opened) 200
Mishimoto (new in box) 16" HD Fan 100
OEM Radiator, hoses, Fans, Fan shroud, ac condenser, and reservoir assembly 400
OEM driver door (no dents, but has some scratches) 250
OEM Driver seat and headrest (mint condition 1200 miles) 250
OEM Fans and shroud 100
OEM Header 150
OEM Overpipe 50
OEM Front Subframe brace 30
OEM Mid pipe or front pipe with cat 80
OEM Window controls driver side 30
OEM Window controls passenger side 20
OEM Driver side fog light (no bulb) 40
OEM Driver side fog light plastic bezel 30
OEM Coolant Reservoir 20
JDM OEM AC delete bracket 200
OEM shifter foam 10
OEM clutch master slave cylinder 20
Whiteline KDT923 diff kit 30
Whiteline KCA326 Camber kit (new) 100
OEM Alternator Pulley cover 5
Whiteline W63414 trailing arm lower bushing kit 40
OEM Driver side rear seat bottom cushion 80
OEM Intake Manifold 80
OEM Center Console foam 40
OEM Dashboard air ducting 20
OEM AC hard line 10
Five:AD Rear Spoiler lip 150
OEM Dashboard glovebox shell 60
OEM Driver side window rail 20
OEM passenger side window rail 20
OEM rear bumper bracket driver side 20
OEM rear driver side taillight bracket 20
OEM Antenna wire 5
OEM fuel diaper bracket 10
OEM Antenna 20
OEM Hood latch 10
OEM Rear center carpet bracket and hardware 10
OEM 2013-2017 Scion FR-S Splash Shield Cover Right 56440CA030 BRZ FRS 13-17 20
OEM 2013-2017 Scion FR-S Mud Flap Guard Left Driver LH FRS BRZ 59123CA030 13-17 15
OEM 2013-2017 Scion FR-S Mud Flap Guard Left Driver LH FRS BRZ 13-1759123CA020 15
OEM Air vent 5
Driver side clear side marker with bulb and harness 15
OEM Scissor jack 20
OEM HPFP Hardlines 10
OEM AIR INTAKE CHAMBER W/ HOSE OEM A40CA00 15
OEM Airbag Module 150
OEM Trunk latch 20
OEM DI ECU 22635JB000 with engine bracket 60
OEM Keyless entry ECU with key fob 250
OEM rear window glass 200
OEM 2013-2017 Scion FR-S Fuel Tank Protector Shield Guard Right Passenger BRZ 13-17 42045CA040 20
OEM taillights 80
OEM Intake snorkel 20
OEM Power Steering control module and column 150
WedsSport SA-10R 18×8.5 +45 5-100 with used 245/45/18 Nitto NT01 race 1200
WedsSport SA-10R 18×8.5 +45 5-100 with like new 245/45/18 Federal 595 RSRR 1450
Thanks. If you cannot find the photo, or would like to request more photos please text me for fastest response. seven zero 2 five four 1 five 3 seven one.
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
The Following User Says Thank You to MicheleAbbate For This Useful Post:
MJones_RB (12-31-2019)
Old 12-31-2019, 05:40 PM   #2
Evil Rocky
Drives: FRS
Does the ACT SB7-HDSS (new never opened) ($580) come with the flywheel?
Evil Rocky is offline   Reply With Quote
Old 12-31-2019, 05:47 PM   #3
MicheleAbbate
Yes
Sent from my SM-N960U using Tapatalk
Old 12-31-2019, 08:04 PM   #4
Joveen
Joveen's Avatar
Drives: Bone stock
The links don't work
Joveen is offline   Reply With Quote
Old 12-31-2019, 10:13 PM   #5
hachigoku
Drives: BRZ, E90 M3
Do you happen to have a driver side fender?
hachigoku is offline   Reply With Quote
Old 12-31-2019, 10:14 PM   #6
MicheleAbbate
No sorry sold those pretty quick
Old 12-31-2019, 10:32 PM   #7
hachigoku
Drives: BRZ, E90 M3
Ah bummer, thanks for replying!
The Following User Says Thank You to hachigoku For This Useful Post:
MicheleAbbate (12-31-2019)
Old 01-01-2020, 02:39 PM   #8
Digger13
Drives: 2019 86
OEM taillights available by chance?
Digger13 is offline   Reply With Quote
Old 01-01-2020, 02:40 PM   #9
MicheleAbbate
Yep they're in there
Old 01-06-2020, 07:02 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Are the AST and Swift springs priced individually or per pair?
Old 01-06-2020, 07:03 PM   #11
MicheleAbbate
Individually but if you need a pair I'll give you a deal. really looking to move this stuff.
finch1750 (01-06-2020)
Old 01-08-2020, 01:24 AM   #12
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
Short block available?
RD1428 is offline   Reply With Quote
Old 01-08-2020, 01:26 AM   #13
MicheleAbbate
Sold all 3 complete.
I have 2 engine cases tho
Old 01-10-2020, 08:14 PM   #14
MicheleAbbate
bump for updated list.
FS: BC Racing BR coil overs (part out) slow n FuRiouS Brakes, Suspension, Chassis 8 10-26-2019 11:03 PM
Massive PART OUT (Aimgain, TRD, carbon fiber) slyder Exterior Parts (Aero, Lighting, Etc.) 9 10-08-2016 11:25 PM
Come watch racing, or be part of it, this weekend (May 16/17). rice_classic Northwest 1 05-12-2015 07:55 PM
Part numbers for 86 Racing parts Surok Scion FR-S / Toyota 86 GT86 General Forum 2 09-20-2013 12:22 AM
Road racing, be a part of it for free. rice_classic Northwest 0 03-03-2013 04:04 PM
