Drives: BRZ 14'
Intake manifold spacers
Drives: 2013 frs red
Copies of Crawford power blocks. I would just look for a used set of Crawfords. I use them combined with header and e85.
#3 | |
Drives: 2013 FRS
![]() Oh lawdy What's your opinion of them? |
#4 | |
Drives: 2017 toyota 86
Lots of data, testing, and dynos I’ve seen show they are not very good paired with E85. Its a one or the other. BPB is the poor mans E85 (or don't have access) A decent bump in power for NA non E85 users but not near what E85 does. |
Drives: 2017 BRZ PP , 2005 Saab 97X
Poor mans E85?
in my experience, the power blocks on an untuned, stock fuel and header, moves the torque dip down a few hundred rpm and nets you a small increase in power at the top end. With E85 and a header the torque dip isnt really there, but what it does now is addes to added mid range torque, you are increase the volumn inside the intake tract is it worth it when you have an intake e85, header and custom tune? Eh hard to say. I would say save the 200 bucks or whatever but the change in the torque dip on the stock tune stock gas car is nice. and coupled with the 4.3 diff makes for a snappy day above 4k rpm |
#6 | |
That is why most people recommend not to use them together with E85 its one or the other with E85 being way better (IE poor mans E85). If you do use them together its not going to blow up your car or be a night and day difference of lack of power, so it still technically "works" just has no positive benefit used together. https://www.ft86club.com/forums/showthread.php?t=62471 https://www.ft86club.com/forums/showthread.php?t=62007 A lot more threads discussing all of this already if you search. The gist is they do work but not well with E85 or with any FI. |
I didn't make any performance claims. Not going to waste time dynoing a 200 hp car.
I put them on before going to e85 and haven't been motivated enough to remove them
not playing cards
Earliest pilots figured out the hard way that their carbs were icing up at altitude.
#10 |
That Guy
Drives: 2013 asphalt FRS MT
There was a video out there years ago of a 427 small block icing it's intake manifold during full power runs on an engine dyno. It was injected but the injectors were at the begginning of the runner vice the end. It was impressive.
#11 | |
ProCrastinationConsultant
#12 |
Drives: 2013 FR-S Argento
They work as Tokyo's links show, but to get the most out of them (as with anything) you need to have a tune optimized for them. Shiv has some tips for optimizing the very top end - these give a noticable boost in the power curve between 5000 and 6500 rpm, and compress the torque dip (they basically compress the entire power curve). They are a good option for the crowd that doesn't want to go FI, limited to pump gas, and have done the other primary power adding mods. That said, you need to make sure to ground your relocated injector driver box, and also they need to be manufactured properly. If they are in any way not flat/don't mate to the heads/manifold well you can have problems with manifold vacuum leaks. I'd stick with the crawford ones - be patient and they pop up used on here for <$200 usually.
*edit* just realized I said "crowd doesn't want to go NA" meant to say "FI" lol Last edited by bfrank1972; 01-13-2020 at 09:59 AM. |
| Intake manifold spacers | GT86>4>ANC | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 11-01-2020 08:33 PM |
| SOLD - please delete | MugsBRZ | Engine, Exhaust, Bolt-Ons | 20 | 01-24-2020 08:12 PM |
| Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) | nelsmar | Engine, Exhaust, Transmission | 295 | 08-25-2018 03:19 PM |
| 2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
| WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
