Old 01-06-2020, 10:08 PM   #1
scsftballnum45
Drives: BRZ 14'
Intake manifold spacers
Has anyone seen or tried these?
https://www.ebay.com/itm/Red-Aluminu....c100935.m2460
scsftballnum45 is offline   Reply With Quote
Old 01-06-2020, 10:20 PM   #2
Lantanafrs2
Drives: 2013 frs red
Copies of Crawford power blocks. I would just look for a used set of Crawfords. I use them combined with header and e85.
Lantanafrs2 is offline   Reply With Quote
Old 01-07-2020, 02:01 AM   #3
Stomachbuzz
Drives: 2013 FRS
Originally Posted by scsftballnum45 View Post
80% off?!
Oh lawdy
What's your opinion of them?
Stomachbuzz is offline   Reply With Quote
Old 01-07-2020, 02:10 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
You have a dyno or any data?
Lots of data, testing, and dynos I’ve seen show they are not very good paired with E85. Its a one or the other. BPB is the poor mans E85 (or don't have access) A decent bump in power for NA non E85 users but not near what E85 does.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
PulsarBeeerz (01-07-2020)
Old 01-07-2020, 02:29 AM   #5
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Poor mans E85?
in my experience, the power blocks on an untuned, stock fuel and header, moves the torque dip down a few hundred rpm and nets you a small increase in power at the top end.
With E85 and a header the torque dip isnt really there, but what it does now is addes to added mid range torque, you are increase the volumn inside the intake tract
is it worth it when you have an intake e85, header and custom tune? Eh hard to say. I would say save the 200 bucks or whatever
but the change in the torque dip on the stock tune stock gas car is nice. and coupled with the 4.3 diff makes for a snappy day above 4k rpm
Clutch Dog is offline   Reply With Quote
Old 01-07-2020, 10:19 AM   #6
86TOYO2k17
Originally Posted by Clutch Dog View Post
Poor mans E85?
It shifts the entire powerband down about 500rpm. so you have power sooner or more power throughout the entire curve below 6500 RPM but not more peak power, as in doing this you start losing and sacrifice top end around 6500+ RPM where E85 starts to really shine. With some tuning and tweaking you can get back some of the top end that is lost but not all of it and not all the way to redline.
That is why most people recommend not to use them together with E85 its one or the other with E85 being way better (IE poor mans E85). If you do use them together its not going to blow up your car or be a night and day difference of lack of power, so it still technically "works" just has no positive benefit used together.
https://www.ft86club.com/forums/showthread.php?t=62471
https://www.ft86club.com/forums/showthread.php?t=62007
A lot more threads discussing all of this already if you search. The gist is they do work but not well with E85 or with any FI.
Old 01-07-2020, 10:44 AM   #7
Lantanafrs2
I didn't make any performance claims. Not going to waste time dynoing a 200 hp car.
Old 01-07-2020, 10:50 AM   #8
Lantanafrs2
I put them on before going to e85 and haven't been motivated enough to remove them
Old 01-07-2020, 05:02 PM   #9
Originally Posted by solidsnake11 View Post
The old air cooled VWs would frost the outside of the intake in summer with there long runners and central carb , probably where the idea of heated throttle bodies came from.
Earliest pilots figured out the hard way that their carbs were icing up at altitude.
solidsnake11 (01-07-2020), wparsons (01-09-2020)
Old 01-09-2020, 12:21 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
There was a video out there years ago of a 427 small block icing it's intake manifold during full power runs on an engine dyno. It was injected but the injectors were at the begginning of the runner vice the end. It was impressive.
The Following 2 Users Say Thank You to Calum For This Useful Post:
solidsnake11 (01-09-2020), Ultramaroon (01-09-2020)
Old 01-09-2020, 09:26 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
note that those don't appear to have the small grounding tab that the crawford version has. that is specifically required to ground the injector control unit. i don't agree that the crawford version is worth almost $300, but it at least comes with a reputable company standing behind it.
BigHugeFatGuy (01-10-2020)
Old 01-10-2020, 09:57 AM   #12
bfrank1972
Drives: 2013 FR-S Argento
They work as Tokyo's links show, but to get the most out of them (as with anything) you need to have a tune optimized for them. Shiv has some tips for optimizing the very top end - these give a noticable boost in the power curve between 5000 and 6500 rpm, and compress the torque dip (they basically compress the entire power curve). They are a good option for the crowd that doesn't want to go FI, limited to pump gas, and have done the other primary power adding mods. That said, you need to make sure to ground your relocated injector driver box, and also they need to be manufactured properly. If they are in any way not flat/don't mate to the heads/manifold well you can have problems with manifold vacuum leaks. I'd stick with the crawford ones - be patient and they pop up used on here for <$200 usually.
*edit* just realized I said "crowd doesn't want to go NA" meant to say "FI" lol
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
Lantanafrs2 (01-10-2020), soundman98 (01-10-2020)
Intake manifold spacers GT86>4>ANC Scion FR-S / Toyota 86 GT86 General Forum 34 11-01-2020 09:33 PM
SOLD - please delete MugsBRZ Engine, Exhaust, Bolt-Ons 20 01-24-2020 09:12 PM
Third Party Testing: Crawford Billet Power Blocks (BPB / Manifold Spacers) nelsmar Engine, Exhaust, Transmission 295 08-25-2018 04:19 PM
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 11:40 AM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 03:24 PM
