Old 12-04-2019, 05:46 PM   #1
Jmk91
Drives: 2017 Brz Performance Package
Idle fluctuating
Without heat or anything on my idle jumps around. Cars 2017 brz with 20k. Bought it used and just noticed this. I do have an after market greedy exhaust. Assuming it’s a vacuum line or something. Common hoses that come lose or anything?
Jmk91 is offline   Reply With Quote
Old 12-04-2019, 06:59 PM   #2
humfrz
Is you car showing any trouble codes? If so, what is it?
Have you had the battery disconnected recently? If so, it could be the ECU just relearning - it will settle down.
If you have the AC ON or the dial set to defrost, it may be the AC compressor cycling - normal.
humfrz
Old 12-04-2019, 07:34 PM   #3
Jmk91
humfrz
No codes. I’d say it fluctuates 100-200 rpm. You definitely can hear and feel it.
Also no on the battery and I’m in Ohio my ac definitely isn’t on currently. I wish it was haha.
Old 12-04-2019, 07:43 PM   #4
Jmk91
Wait so if I even have heat on defrost it’ll cause it? If so that’s my issue. I didn’t notice it till today. I’m at work now so I can’t test it out.
Old 12-04-2019, 07:50 PM   #5
humfrz
When you have the defrost ON, the AC compressor will cycle on and off, causing a slight change in the idle speed.
Why? Because the AC removes some of the moisture in the air it is circulating so the defroster will work better.
humfrz
Old 12-05-2019, 12:11 AM   #6
Jmk91
Yep that was issue alright never noticed it so much with any other car I’ve ever had. Definitely noticeable in the brz. Thanks for the replies.
Old 12-07-2019, 03:09 PM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
IS the car not still under warranty being a 2017?
AC hot air during idle Initial_RD Issues | Warranty | Recalls / TSB 13 07-30-2019 07:41 AM
Idle dip but going FI mscamp02 Forced Induction 16 11-09-2015 03:16 PM
Idle at 4 psi? LS1M Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 07-18-2015 12:01 PM
K&N idle dip Dominus Engine, Exhaust, Transmission 7 01-28-2015 10:17 PM
Fluctuating volume so26 Issues | Warranty | Recalls / TSB 9 08-16-2012 12:26 AM
